メインコンテンツにスキップ
Velocity Micro Cruz T301 Speakers Replacement
必要な工具と部品
  1. Velocity Micro Cruz T301 Speakers Replacement, Speakers: 手順 1、 1の画像 1
    • Insert an opening tool in the SD port, with the edge pointing towards the rear panel.
    • Use the opening tool to pry the back plate up.
  2. Velocity Micro Cruz T301 Speakers Replacement: 手順 2、 1の画像 1
    • Insert a second opening tool into the space created by the first opening tool.
  3. Velocity Micro Cruz T301 Speakers Replacement: 手順 3、 1の画像 1
    • Remove the first opening tool.
  4. Velocity Micro Cruz T301 Speakers Replacement: 手順 4、 2の画像 1 Velocity Micro Cruz T301 Speakers Replacement: 手順 4、 2の画像 2
    • Slide the opening tool across the back plate to disconnect the clips joining the plate to the tablet.
  5. Velocity Micro Cruz T301 Speakers Replacement: 手順 5、 1の画像 1
    • Remove the four screws in the metal plate covering the battery using a Phillips #0 screwdriver.
  6. Velocity Micro Cruz T301 Speakers Replacement: 手順 6、 1の画像 1
    • Using a plastic spudger to remove the battery connector.
    • Failure to follow this step may result in an electric shock.
  7. Velocity Micro Cruz T301 Speakers Replacement: 手順 7、 1の画像 1
    • Remove the battery with a spudger.
    • The photos in this guide use a metal spudger. Do not use a metal spudger as it can damage the device or conduct electricity causing a shock.
  8. Velocity Micro Cruz T301 Speakers Replacement: 手順 8、 1の画像 1
    • Remove the twelve screws in the cover with a Phillips #0 screwdriver.
  9. Velocity Micro Cruz T301 Speakers Replacement: 手順 9、 1の画像 1
    • Place a spudger between the tablet base and the screen.
    • Again this photo shows the use of a metal spudger. The use of a metal spudger can cause damage to the device and can lead to an electric shock.
  10. Velocity Micro Cruz T301 Speakers Replacement: 手順 10、 1の画像 1
    • Move the spudger around the face to release the clips attached to the tablet base.
  11. Velocity Micro Cruz T301 Speakers Replacement: 手順 11、 1の画像 1
    • Locate the speaker on the motherboard. Use the plastic spudger to disconnect the speaker from the connection port.
    • Plug the new speaker into the port, then use the plastic spudger to gently push it in.
終わりに
作成者
4人の作成者と共同で作成されました。
Ali Rashid Al Araimi
メンバー登録日: 10/05/16
371 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 1-6, Cagle Fall 2016 USF Tampa, Team 1-6, Cagle Fall 2016人のメンバー
USFT-CAGLE-F16S1G6
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 103
