メインコンテンツにスキップ
Velocity Micro Cruz T301 Motherboard Replacement
必要な工具と部品
  1. Velocity Micro Cruz T301 Motherboard  Replacement, Motherboard: 手順 1、 1の画像 1
    • Insert the plastic opening tool in the SD port. The edge point should be pointed towards the rear panel.
  2. Velocity Micro Cruz T301 Motherboard  Replacement: 手順 2、 1の画像 1
    • Insert a small opening tool between the rear panel and the tablet.
  3. Velocity Micro Cruz T301 Motherboard  Replacement: 手順 3、 1の画像 1
    • The large opening tool is not needed any more.
  4. Velocity Micro Cruz T301 Motherboard  Replacement: 手順 4、 2の画像 1 Velocity Micro Cruz T301 Motherboard  Replacement: 手順 4、 2の画像 2
    • Move the small tool opener around the rear panel to free the 12 edges.
  5. Velocity Micro Cruz T301 Motherboard  Replacement: 手順 5、 1の画像 1
    • Using PH0 Phillips Driver, remove the 4 Screws in the Metal part.
  6. Velocity Micro Cruz T301 Motherboard  Replacement: 手順 6、 1の画像 1
    • Using a plastic Spudger remove the battery connector.
  7. Velocity Micro Cruz T301 Motherboard  Replacement: 手順 7、 1の画像 1
    • Using PH0 Phillips Driver, remove the 12 Screws in the cover.
  8. Velocity Micro Cruz T301 Motherboard  Replacement: 手順 8、 1の画像 1
    • Place a metal Spudger between the tablet and the back cover.
  9. Velocity Micro Cruz T301 Motherboard  Replacement: 手順 9、 1の画像 1
    • Move the spudger around the tablet to release the clips attached to the tablet.
  10. Velocity Micro Cruz T301 Motherboard  Replacement: 手順 10、 1の画像 1
    • Use a plastic spudger to release the connection between the speakers and the motherboard as shown in the picture.
  11. Velocity Micro Cruz T301 Motherboard  Replacement: 手順 11、 1の画像 1
    • This guide shows the use of incorrect tools. Always use ESD safe tools when dealing with delicate internal components.
    • Use a nylon spudger to remove the top plug connector from the motherboard.
  12. Velocity Micro Cruz T301 Motherboard  Replacement: 手順 12、 2の画像 1 Velocity Micro Cruz T301 Motherboard  Replacement: 手順 12、 2の画像 2
    • Use a metal spudger to remove both screen cable connectors
  13. Velocity Micro Cruz T301 Motherboard  Replacement: 手順 13、 1の画像 1
    • use openning tools to remove the motherboard.
終わりに
作成者
3人の作成者と共同で作成されました。
Ahmed
メンバー登録日: 10/05/16
227 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 1-6, Cagle Fall 2016 USF Tampa, Team 1-6, Cagle Fall 2016人のメンバー
USFT-CAGLE-F16S1G6
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 165
