メインコンテンツにスキップ
VanMoof No 3 Light Battery Replacement
必要な工具と部品
  1. VanMoof No 3 Light Battery Replacement, Battery: 手順 1、 3の画像 1 VanMoof No 3 Light Battery Replacement, Battery: 手順 1、 3の画像 2 VanMoof No 3 Light Battery Replacement, Battery: 手順 1、 3の画像 3
    • Buy two, "2/3" AAA NiCad rechargeable batteries. Better still get four so you can replace the batteries in both lights.
    • Get the batteries with solder tabs
  2. VanMoof No 3 Light Battery Replacement, Disassemble the light: 手順 2、 1の画像 1
    • Nothing to it really - just remove the 2 cross point screws
  3. VanMoof No 3 Light Battery Replacement, Remove the battery: 手順 3、 2の画像 1 VanMoof No 3 Light Battery Replacement, Remove the battery: 手順 3、 2の画像 2
    • Use a flat blade screw driver to pull the battery from the adhesive tape.
    • Remove the heat shrink plastic joining the batteries
  4. VanMoof No 3 Light Battery Replacement, Unsolder the battery: 手順 4、 2の画像 1 VanMoof No 3 Light Battery Replacement, Unsolder the battery: 手順 4、 2の画像 2
    • Unsolder the wires
  5. VanMoof No 3 Light Battery Replacement, Solder the new battery: 手順 5、 3の画像 1 VanMoof No 3 Light Battery Replacement, Solder the new battery: 手順 5、 3の画像 2 VanMoof No 3 Light Battery Replacement, Solder the new battery: 手順 5、 3の画像 3
    • Tin the battery tabs
    • Join together with tape. You'll remove this later. Both +ve ends are joined
    • The red wire goes on the end of the battery that has a ridge.
  6. VanMoof No 3 Light Battery Replacement, Join the batteries: 手順 6、 1の画像 1
    • Remove the temporary tape
    • Fold the tabs inwards
    • Cover with 2 pieces of insulation tape. The wires will come out of the middle, between the pieces of tape
  7. VanMoof No 3 Light Battery Replacement, Reassemble: 手順 7、 3の画像 1 VanMoof No 3 Light Battery Replacement, Reassemble: 手順 7、 3の画像 2 VanMoof No 3 Light Battery Replacement, Reassemble: 手順 7、 3の画像 3
    • Put the small black cup back on the switch. The dome goes outwards.
    • Put the outer switch in the lense. It goes in the smaller hole
    • The black body will be flush when it's pushed together.
  8. VanMoof No 3 Light Battery Replacement, Reassemble 2: 手順 8、 2の画像 1 VanMoof No 3 Light Battery Replacement, Reassemble 2: 手順 8、 2の画像 2
    • Test the light turns on
    • Screw the back plate to the lense.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Martin Hampton
メンバー登録日: 02/13/16
1,308 ポイント
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 39
過去 30 日: 151
今までの合計 7,783
