はじめに
An instructional video for installing a pop-top tent on a Vanagon (1985-1991). This video gives you everything you need to know in order to install the screw-in style tent.
Not to be confused with the staple in type found on the earlier 1980-1985 Westfalia. If you are unsure of which style you have, the screw-in style will have metal rails attaching the tent at the top.
This repair is best done with a friend or two as it is recommended that the fiberglass top is removed from the vehicle.
必要な工具と部品
ビデオインストラクション
Make sure to keep the new tent clean and dry as this will allow it to last for years.
0 件のコメント
