メインコンテンツにスキップ
VanMoof No 3 - Upgrade to 8-speed gear
必要な工具と部品
  1. VanMoof No 3 -  Upgrade to 8-speed gear, What you'll need: 手順 1、 1の画像 1
    • Shimano SG-C6001-8C Nexus 8. This is the one with the coaster brake.
    • Chain ring, gear lever, seals, and clips
    • Shimano Grip Shifter Nexus 8-speed Sl-C60008
    • Gear cable (inner and outer)
    • Spokes 36 * 284mm stainless steel spokes
  2. VanMoof No 3 -  Upgrade to 8-speed gear, Double check your spoke length: 手順 2、 1の画像 1
    • Measure the inside diameter of your wheel
    • Use this calculator https://leonard.io/edd/
    • Add 2mm. You should get 284mm spokes
    • I brought silver Halo spokes from ebay. They are decent quality and have not rusted.
    • You need to stretch the rear frame dropouts because the 8-speed hub is wider (135mm) than the 3-speed one (110mm)
    • I got my local bike shop to do this because there's a risk for damaging your frame.
    • The cost was $150 AUD
  3. VanMoof No 3 -  Upgrade to 8-speed gear, Replace the spokes: 手順 4、 2の画像 1 VanMoof No 3 -  Upgrade to 8-speed gear, Replace the spokes: 手順 4、 2の画像 2
    • Remove all the old spokes from your wheel
    • Spoke the 8 speed gear into the wheel. This is the best guide https://www.youtube.com/watch?v=mIU6mi0K...
    • Tighten all the spokes using a screwdriver. Use the same torque on the screwdriver and check by "plucking" the spokes so they sound the same
    • Turn the bike upside down, install the wheel, and true the wheel. I hold a screwdriver against the frame and slowly spin the wheel. When it moves in, I just tighten the opposite spokes
  4. VanMoof No 3 -  Upgrade to 8-speed gear, Install back wheel and cable: 手順 5、 1の画像 1
    • Pull the old inner cable out from the front
    • Push the new inner cable into the old outer cable
    • Pull the old outer gear cable out of the back of the bottom of the frame. LEAVE THE INNER CABLE IN so you can use it as a guide through the frame.
    • Push the new outer cable in from the back
  5. VanMoof No 3 -  Upgrade to 8-speed gear, Replace the gear twist: 手順 6、 1の画像 1
    • Remove the handlebar grip. I pushed a spoke between the grip and the bar and rolled the spoke to loosen the grip
    • Install new gear change
    • Replace the handle bar grip. I wiped the handle bar and inside grip with alcohol.
    • Connect the gear cable.
    • Use a spoke to rotate the gear change
ゴール
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Martin Hampton
メンバー登録日: 02/13/16
1,308 ポイント
7のガイドは作成済み
2件のガイドコメント
Would this be a possible solution for a bike with a broken eshifter? I have an x3 with err44 and cannot find a replacement part.
Jon Stewart - 返信
I've seen a few e-shifters for sale on facebook, and there are guides on how to fix the electronics so I'd probably go that route. The main problem I can think of with changing to the 8 speed is you'll need to deal with e-shifter wire and you'll need to route the gear change cable on frame. Good luck!
Martin Hampton -
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 30
今までの合計 2,408
