メインコンテンツにスキップ
VTechCS6719-16 Ringer Replacment
必要な工具と部品
  1. VTechCS6719-16 Ringer Replacment, Ringer: 手順 1、 1の画像 1
    • Remove sliding back cover from case.
  2. VTechCS6719-16 Ringer Replacment: 手順 2、 1の画像 1
    • Lift the battery and unplug the two pin cable from phone base.
  3. VTechCS6719-16 Ringer Replacment: 手順 3、 1の画像 1
    • Slide back cover off the phone
    • Located at the bottom of the frame are the two-10 mm screws.
    • Use a Phillips head screwdriver to remove both 10 mm screws.
    • It is recommended to use a magnetic mat or place the screws on an easy to see surface. They will be needed when the phone is reassembled.
  4. VTechCS6719-16 Ringer Replacment: 手順 4、 1の画像 1
    • After removing the two screws from the back of the phone carefully use the metal spudger to lift along the edges and raise the phone case from the internal clips.
  5. VTechCS6719-16 Ringer Replacment: 手順 5、 1の画像 1
    • Once the case is lifted, the board should be freed except for the connection between the ringer and the case.
    • Be careful do not pull the case away from the phone in a jerking or aggressive motion.
  6. VTechCS6719-16 Ringer Replacment: 手順 6、 1の画像 1
    • Using the spudger lift the latch over the ringer to release it.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger should be used whenever possible.
  7. VTechCS6719-16 Ringer Replacment: 手順 7、 1の画像 1
    • The last component of the latch is soldered to the circuit board. This will take some soldering expertise.
終わりに
作成者
3人の作成者と共同で作成されました。
Charles montes
メンバー登録日: 10/20/16
513 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 5-5, Martin Fall 2016 UMass Dartmouth, Team 5-5, Martin Fall 2016人のメンバー
UMASSD-MARTIN-F16S5G5
3 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 14
今までの合計 304
