メインコンテンツにスキップ
VTech Write and Learn Creative Center Speaker Replacement
必要な工具と部品
  1. VTech Write and Learn Creative Center Speaker Replacement, Back Panel: 手順 1、 3の画像 1 VTech Write and Learn Creative Center Speaker Replacement, Back Panel: 手順 1、 3の画像 2 VTech Write and Learn Creative Center Speaker Replacement, Back Panel: 手順 1、 3の画像 3
    • Remove all eleven 9mm PH 2 Phillips screws securing the back of the case.
  2. VTech Write and Learn Creative Center Speaker Replacement, Speaker: 手順 2、 3の画像 1 VTech Write and Learn Creative Center Speaker Replacement, Speaker: 手順 2、 3の画像 2 VTech Write and Learn Creative Center Speaker Replacement, Speaker: 手順 2、 3の画像 3
    • In order to remove the speaker, you must desolder the two wires connecting it to the circuit board.
    • When you desolder, apply the tip of the soldering iron to the soldered joint for approximately 5 - 10 seconds.
    • The soldered joint will turn to a liquid consistency. At this moment, remove the wire and soldering iron.
    • Repeat each of the following steps for the second soldered joint.
    • Soldering irons are dangerously hot. The soldering iron should only come in contact with joints being desoldered or soldered.
    • Make sure to allow time for your soldering iron to heat up before using it.
    • Make sure the tip of the soldering iron is cleaned so the tin on the tip is exposed. This will allow the soldering iron to work efficiently.
  3. VTech Write and Learn Creative Center Speaker Replacement: 手順 3、 2の画像 1 VTech Write and Learn Creative Center Speaker Replacement: 手順 3、 2の画像 2
    • Remove the 2 5mm PH 0 Phillips screws with 10 mm heads that secure the speaker to the front of the case.
終わりに
作成者
3人の作成者と共同で作成されました。
Victoria Hathaway
メンバー登録日: 04/06/16
310 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 1-2, Miles Spring 2016 UMass Dartmouth, Team 1-2, Miles Spring 2016人のメンバー
UMASSD-MILES-S16S1G2
3 メンバー
12のガイドは作成済み
1件のガイドコメント
Where can I buy the speaker
Lesa Thomas - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 19
今までの合計 1,355
