メインコンテンツにスキップ
VTech Write and Learn Creative Center Magnetic Screen Replacement
必要な工具と部品
  1. VTech Write and Learn Creative Center Magnetic Screen Replacement, Back Panel: 手順 1、 3の画像 1 VTech Write and Learn Creative Center Magnetic Screen Replacement, Back Panel: 手順 1、 3の画像 2 VTech Write and Learn Creative Center Magnetic Screen Replacement, Back Panel: 手順 1、 3の画像 3
    • Remove all eleven 9mm PH 2 Phillips screws securing the back of the case.
  2. VTech Write and Learn Creative Center Magnetic Screen Replacement, Slider: 手順 2、 1の画像 1
    • Remove the two 7mm PH 0 Phillips screws holding the slider to the slider handle.
    • The back of the slider will likely be coated in lubricant. Be careful not to make a mess.
  3. VTech Write and Learn Creative Center Magnetic Screen Replacement, Magnetic Screen: 手順 3、 2の画像 1 VTech Write and Learn Creative Center Magnetic Screen Replacement, Magnetic Screen: 手順 3、 2の画像 2
    • Remove the four 5mm PH 0 Phillips screws with 7mm heads holding the screen to the front of the case.
  4. VTech Write and Learn Creative Center Magnetic Screen Replacement: 手順 4、 1の画像 1
    • Gently push the edges of the screen to remove it from the front case.
終わりに
作成者
4人の作成者と共同で作成されました。
Philip Zietkowski
メンバー登録日: 03/25/16
342 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 1-2, Miles Spring 2016 UMass Dartmouth, Team 1-2, Miles Spring 2016人のメンバー
UMASSD-MILES-S16S1G2
3 メンバー
12のガイドは作成済み
2件のガイドコメント
Thank you for this! Do you have suggestions on how to fix the magnetic screen or get a replacement? I emailed the manufacturer (B. Toys for mine) and unfortunately they replied, “​We replace the full toy only, and do not offer the internal parts as replacements.“ But I don’t want all the rest of the plastic - I just want the magnets on the screen to properly appear and disappear. Instead, its like the magnetic powder floats so it’s constantly grey rather than clear or magnetized.
Katie - 返信
Hello I got the same issue i dont know how to fix ot of you mine is not even an year old but still get that grey screen plz help n let me know how to get rid of it Thankyou
wings_latif -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 22
今までの合計 1,612
