はじめに
This guide will show the necessary steps to clear the touchscreen contacts on a VTech Touch and Swipe Baby Phone if it has become unresponsive. In order to clean the touchscreen, you will need to unscrew the battery casing and remove the display from the device. If cleaning the touchscreen contacts does not fix the problem, replace the touchscreen of the VTech Touch and Swipe Baby Phone. This guide will also teach you how to re-align the display.
必要な工具と部品
Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
Remove four 13.8mm screws from the back of the device using a Phillips #1 screwdriver.
To reassemble, align the two black lines together by moving the belt back and forth.
Once aligned reinsert the toothed slider at the exact point shown.
be careful at the top blue button (on/off) that might come off when you align the belt
Lift the assembly to gain access to the connection point under the assembly.
3 の人々がこのガイドを完成させました。
5 件のコメント
Before I attempt this: Does this address the problem of the touch screen no longer responding and the device playing the same sound repeatedly?
Well, the answer to my own question is “no”.
@larsgilbert did you find a fix to your problem? I have the same problem!
Regrettably, no.
