メインコンテンツにスキップ
VTech Spin and Learn Color Flashlight Red Ring Replacement
必要な工具と部品
  1. VTech Spin and Learn Color Flashlight Red Ring Replacement, Battery Housing: 手順 1、 2の画像 1 VTech Spin and Learn Color Flashlight Red Ring Replacement, Battery Housing: 手順 1、 2の画像 2
    • Locate the battery housing on the back of the flashlight as pictured.
    • Unscrew the single 8 mm Phillips #1 screw.
    • The screw will stay attached to the cover that will be removed.
    • Lift the battery housing cover to reveal the battery terminals. Remove the batteries.
  2. VTech Spin and Learn Color Flashlight Red Ring Replacement, Red Ring: 手順 2、 3の画像 1 VTech Spin and Learn Color Flashlight Red Ring Replacement, Red Ring: 手順 2、 3の画像 2 VTech Spin and Learn Color Flashlight Red Ring Replacement, Red Ring: 手順 2、 3の画像 3
    • Locate the screw covering stickers on the side of the red ring. These two stickers will be slightly larger than the normal stickers. In this case it was a ladybug and a duck on opposite sides of the ring.
    • With a plastic opening tool, gently remove the stickers by prying around the edges. Be careful with these as you will want to reapply them later
  3. VTech Spin and Learn Color Flashlight Red Ring Replacement: 手順 3、 3の画像 1 VTech Spin and Learn Color Flashlight Red Ring Replacement: 手順 3、 3の画像 2 VTech Spin and Learn Color Flashlight Red Ring Replacement: 手順 3、 3の画像 3
    • Remove the two 8mm Phillips #0 screws from the screw channels found under the stickers in step one. This can be seen in the first photo if step 2.
    • Once the screws have been successfully removed, grasp one half of the ring and pull gently to separate it from the yellow housing. Repeat on the opposite side and the ring is disassembled.
終わりに
作成者
3人の作成者と共同で作成されました。
Nathaniel Troyer
メンバー登録日: 08/27/15
441 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 2-6, Blackwell Fall 2015 USF Tampa, Team 2-6, Blackwell Fall 2015人のメンバー
USFT-BLACKWELL-F15S2G6
3 メンバー
18のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 13
今までの合計 304
