メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
VTech Safe and Sound DM111-2 Antenna Replacement
必要な工具と部品
  1. VTech Safe and Sound DM111-2 Antenna Replacement, Battery: 手順 1、 1の画像 1
    • Expose the battery compartment by removing the lower back cover of the device.
    • Do this by holding the back side of the device upside down in your hands and applying pressure to the indented portion with both thumbs.
    FixBotに聞いてみる
    コメントを追加
  2. VTech Safe and Sound DM111-2 Antenna Replacement: 手順 2、 1の画像 1
    • Once the batteries are exposed, use your index finger to push the battery against the spring and pull up to dislodge the battery.
    • Make sure to check for battery acid or other corrosive substances before touching the battery. If needed, use latex gloves to avoid skin irritation from battery acid.
    FixBotに聞いてみる
    コメントを追加
  3. VTech Safe and Sound DM111-2 Antenna Replacement, Antenna: 手順 3、 1の画像 1
    • Using a Phillips #00 screwdriver, remove the two 11.2 mm Philips #00 screws located on either side of the battery slots.
    FixBotに聞いてみる
    コメントを追加
  4. VTech Safe and Sound DM111-2 Antenna Replacement: 手順 4、 2の画像 1 VTech Safe and Sound DM111-2 Antenna Replacement: 手順 4、 2の画像 2
    • Insert the plastic opening tool into the seam between the front and back coverings to create a gap.
    • The tools edge should point toward the front covering. It is easiest to start from the bottom of the device and slide the tool around the seam until all clips have been separated from the tabs.
    • When separating the front and back cover, be careful not to separate the red and black wires which connect the batteries to the motherboard. Do not forcefully pull the two coverings apart.
    FixBotに聞いてみる
    コメントを追加
  5. VTech Safe and Sound DM111-2 Antenna Replacement: 手順 5、 3の画像 1 VTech Safe and Sound DM111-2 Antenna Replacement: 手順 5、 3の画像 2 VTech Safe and Sound DM111-2 Antenna Replacement: 手順 5、 3の画像 3
    • Unscrew the two 6.8 mm Phillips #00 screws located on the motherboard.
    • When separating the motherboard from the front cover, be careful not to separate the two red wires which connect the speaker to the motherboard.
    • Once you've safely detached the two units, now relocate the Antenna. Flip the device and locate the solder points.
    • Using a Soldering Iron, detach the Antenna and solder a new antenna.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
5人の作成者と共同で作成されました。
Naman Johri
メンバー登録日: 08/31/15
191 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 6-3, Remmell Fall 2015 USF Tampa, Team 6-3, Remmell Fall 2015人のメンバー
USFT-REMMELL-F15S6G3
4 メンバー
7のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 60
今までの合計 2,742
