メインコンテンツにスキップ
はじめに
In order to remove the screen or the battery, the main board will have to be removed first. Follow this guide to set you on your way.
パーツ
パーツは指定されていません。
  1. Begin by flipping the watch over with its back facing upwards. Begin by flipping the watch over with its back facing upwards.
    • Begin by flipping the watch over with its back facing upwards.
  2. Next, use the Phillips #00 screwdriver to unscrew the four 6.0 mm screws located in each corner of the watch to remove the backplate. Next, use the Phillips #00 screwdriver to unscrew the four 6.0 mm screws located in each corner of the watch to remove the backplate.
    • Next, use the Phillips #00 screwdriver to unscrew the four 6.0 mm screws located in each corner of the watch to remove the backplate.
  3. Gently lift the backplate up to remove it. Gently lift the backplate up to remove it.
    • Gently lift the backplate up to remove it.
  4. MacBook Battery 修理キット
    最低価格 $69.99
    Buy Now
    最低価格 $69.99
    Buy Now
  5. After removing the backplate, lift the master switch up from the circuit board. After removing the backplate, lift the master switch up from the circuit board. After removing the backplate, lift the master switch up from the circuit board.
    • After removing the backplate, lift the master switch up from the circuit board.
  6. Using a Phillips #00 screwdriver,  remove the 0.6 mm screw.
    • Using a Phillips #00 screwdriver, remove the 0.6 mm screw.
  7. Carefully remove the speaker from the case without disconnecting it from the motherboard. Carefully remove the speaker from the case without disconnecting it from the motherboard.
    • Carefully remove the speaker from the case without disconnecting it from the motherboard.
  8. Using the tweezers, carefully lift the bar holding the connection to the screen. Remove the motherboard from the device.
    • Using the tweezers, carefully lift the bar holding the connection to the screen.
    • Remove the motherboard from the device.
まとめ
Jessica Richard
メンバー登録日: 2018年10月25日
479 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team S3-G5, Peak Fall 2018 UMass Dartmouth, Team S3-G5, Peak Fall 2018人のメンバー
UMASSD-PEAK-F18S3G5
4 メンバー
7のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 57
今までの合計 318
