メインコンテンツにスキップ
VTech Kidizoom Camera Connect Shutter Button Replacement
必要な工具と部品
  1. VTech Kidizoom Camera Connect Shutter Button Replacement, Front Case: 手順 1、 2の画像 1 VTech Kidizoom Camera Connect Shutter Button Replacement, Front Case: 手順 1、 2の画像 2
    • Remove batteries and SD card before beginning disassembly!
    • Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
  2. VTech Kidizoom Camera Connect Shutter Button Replacement: 手順 2、 2の画像 1 VTech Kidizoom Camera Connect Shutter Button Replacement: 手順 2、 2の画像 2
    • Remove all four (11mm) screws with the Philips #0 screwdriver.
  3. VTech Kidizoom Camera Connect Shutter Button Replacement: 手順 3、 3の画像 1 VTech Kidizoom Camera Connect Shutter Button Replacement: 手順 3、 3の画像 2 VTech Kidizoom Camera Connect Shutter Button Replacement: 手順 3、 3の画像 3
    • Remove the two battery cartridges located on the underside of the camera.
    • Once cartridges are removed, use the metal spudger to pry open the top, bottom, and both sides of the camera.
  4. VTech Kidizoom Camera Connect Shutter Button Replacement: 手順 4、 1の画像 1
    • Beware of the two black viewfinder lens falling out as you pry open the device!
    • The device should now be open and ready for further repair and/or replacement parts.
  5. VTech Kidizoom Camera Connect Shutter Button Replacement, Shutter Button: 手順 5、 1の画像 1
    • Remove the purple plastic that covers the button and circuit board. It should slide right out from the slot it sits in.
  6. VTech Kidizoom Camera Connect Shutter Button Replacement: 手順 6、 1の画像 1
    • Unsolder wires connected to the right side of the circuit board. Pull the wires to the side.
  7. VTech Kidizoom Camera Connect Shutter Button Replacement: 手順 7、 2の画像 1 VTech Kidizoom Camera Connect Shutter Button Replacement: 手順 7、 2の画像 2
    • The button/circuit board should be loose now. Gently pull out the button/circuit board to remove it from the device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Justin Sanchez
メンバー登録日: 02/08/16
520 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 6-4, Eyestone Spring 2016 USF Tampa, Team 6-4, Eyestone Spring 2016人のメンバー
USFT-EYESTONE-S16S6G4
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 14
今までの合計 921
