メインコンテンツにスキップ
VTech Kidizoom Camera Connect Motherboard Replacement
必要な工具と部品
  1. VTech Kidizoom Camera Connect Motherboard Replacement, Front Case: 手順 1、 2の画像 1 VTech Kidizoom Camera Connect Motherboard Replacement, Front Case: 手順 1、 2の画像 2
    • Remove batteries and SD card before beginning disassembly!
    • Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
  2. VTech Kidizoom Camera Connect Motherboard Replacement: 手順 2、 2の画像 1 VTech Kidizoom Camera Connect Motherboard Replacement: 手順 2、 2の画像 2
    • Remove all four (11mm) screws with the Philips #0 screwdriver.
  3. VTech Kidizoom Camera Connect Motherboard Replacement: 手順 3、 3の画像 1 VTech Kidizoom Camera Connect Motherboard Replacement: 手順 3、 3の画像 2 VTech Kidizoom Camera Connect Motherboard Replacement: 手順 3、 3の画像 3
    • Remove the two battery cartridges located on the underside of the camera.
    • Once cartridges are removed, use the metal spudger to pry open the top, bottom, and both sides of the camera.
  4. VTech Kidizoom Camera Connect Motherboard Replacement: 手順 4、 1の画像 1
    • Beware of the two black viewfinder lens falling out as you pry open the device!
    • The device should now be open and ready for further repair and/or replacement parts.
  5. VTech Kidizoom Camera Connect Motherboard Replacement, Motherboard: 手順 5、 1の画像 1
    • Locate and remove the screws circled in the provided image with a Philips #0 screwdriver.
  6. VTech Kidizoom Camera Connect Motherboard Replacement: 手順 6、 2の画像 1 VTech Kidizoom Camera Connect Motherboard Replacement: 手順 6、 2の画像 2
    • Unsolder the connection points on the motherboard.
  7. VTech Kidizoom Camera Connect Motherboard Replacement: 手順 7、 3の画像 1 VTech Kidizoom Camera Connect Motherboard Replacement: 手順 7、 3の画像 2 VTech Kidizoom Camera Connect Motherboard Replacement: 手順 7、 3の画像 3
    • Unsolder the connections to the right battery terminal. Removing the terminal allows easier access to the motherboard.
  8. VTech Kidizoom Camera Connect Motherboard Replacement: 手順 8、 3の画像 1 VTech Kidizoom Camera Connect Motherboard Replacement: 手順 8、 3の画像 2 VTech Kidizoom Camera Connect Motherboard Replacement: 手順 8、 3の画像 3
    • Carefully pull up on the motherboard and pink plastic underneath the motherboard. The pink plastic contains the display and is connected to the motherboard.
終わりに
5 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Justin Sanchez
メンバー登録日: 02/08/16
544 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 6-4, Eyestone Spring 2016 USF Tampa, Team 6-4, Eyestone Spring 2016人のメンバー
USFT-EYESTONE-S16S6G4
4 メンバー
5のガイドは作成済み
1件のガイドコメント
Do you know what the replacement mic is? My girls mic has stopped working. Sound still plays, but can’t record voice or sound for video making. Thanks Tim
Timothy GRAHAM - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 17
今までの合計 2,711
