メインコンテンツにスキップ
VTech Kidizoom Camera Connect Motherboard Replacement
必要な工具と部品
  1. VTech Kidizoom Camera Connect Motherboard Replacement, Front Case: 手順 1、 2の画像 1 VTech Kidizoom Camera Connect Motherboard Replacement, Front Case: 手順 1、 2の画像 2
    • Remove batteries and SD card before beginning disassembly!
    • Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
  2. VTech Kidizoom Camera Connect Motherboard Replacement: 手順 2、 2の画像 1 VTech Kidizoom Camera Connect Motherboard Replacement: 手順 2、 2の画像 2
    • Remove all four (11mm) screws with the Philips #0 screwdriver.
  3. VTech Kidizoom Camera Connect Motherboard Replacement: 手順 3、 3の画像 1 VTech Kidizoom Camera Connect Motherboard Replacement: 手順 3、 3の画像 2 VTech Kidizoom Camera Connect Motherboard Replacement: 手順 3、 3の画像 3
    • Remove the two battery cartridges located on the underside of the camera.
    • Once cartridges are removed, use the metal spudger to pry open the top, bottom, and both sides of the camera.
  4. VTech Kidizoom Camera Connect Motherboard Replacement: 手順 4、 1の画像 1
    • Beware of the two black viewfinder lens falling out as you pry open the device!
    • The device should now be open and ready for further repair and/or replacement parts.
  5. VTech Kidizoom Camera Connect Motherboard Replacement, Motherboard: 手順 5、 1の画像 1
    • Locate and remove the screws circled in the provided image with a Philips #0 screwdriver.
  6. VTech Kidizoom Camera Connect Motherboard Replacement: 手順 6、 2の画像 1 VTech Kidizoom Camera Connect Motherboard Replacement: 手順 6、 2の画像 2
    • Unsolder the connection points on the motherboard.
  7. VTech Kidizoom Camera Connect Motherboard Replacement: 手順 7、 3の画像 1 VTech Kidizoom Camera Connect Motherboard Replacement: 手順 7、 3の画像 2 VTech Kidizoom Camera Connect Motherboard Replacement: 手順 7、 3の画像 3
    • Unsolder the connections to the right battery terminal. Removing the terminal allows easier access to the motherboard.
  8. VTech Kidizoom Camera Connect Motherboard Replacement: 手順 8、 3の画像 1 VTech Kidizoom Camera Connect Motherboard Replacement: 手順 8、 3の画像 2 VTech Kidizoom Camera Connect Motherboard Replacement: 手順 8、 3の画像 3
    • Carefully pull up on the motherboard and pink plastic underneath the motherboard. The pink plastic contains the display and is connected to the motherboard.
終わりに
5 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Justin Sanchez
メンバー登録日: 02/08/16
520 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 6-4, Eyestone Spring 2016 USF Tampa, Team 6-4, Eyestone Spring 2016人のメンバー
USFT-EYESTONE-S16S6G4
4 メンバー
5のガイドは作成済み
コメント 1 件
Do you know what the replacement mic is? My girls mic has stopped working. Sound still plays, but can’t record voice or sound for video making. Thanks Tim
Timothy GRAHAM - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 14
今までの合計 2,300
