メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
VTech InnoTab 2s Screen Replacement
必要な工具と部品
    1. VTech InnoTab 2s Screen Replacement, Back Panel: 手順 1、 1の画像 1
      • Turn your device to where the back panel is facing you.
      FixBotに聞いてみる
      コメントを追加
    2. VTech InnoTab 2s Screen Replacement: 手順 2、 2の画像 1 VTech InnoTab 2s Screen Replacement: 手順 2、 2の画像 2
      • Lift the Leg all the way up and twist the bottom to remove.
      • Once the bottom part pops out the whole leg should just come off.
      • Remove any game cartridge from the device.
      FixBotに聞いてみる
      コメントを追加
    3. VTech InnoTab 2s Screen Replacement: 手順 3、 3の画像 1 VTech InnoTab 2s Screen Replacement: 手順 3、 3の画像 2 VTech InnoTab 2s Screen Replacement: 手順 3、 3の画像 3
      • Remove all of the plastic tabs on the device. These are covering screws that will need to be removed.
      • These covers are made of hard plastic so they may be difficult to remove.
      • There is a special tab in the cartridge cover that is made of rubber, make sure to not break this tab.
      FixBotに聞いてみる
      コメントを追加
    4. VTech InnoTab 2s Screen Replacement: 手順 4、 2の画像 1 VTech InnoTab 2s Screen Replacement: 手順 4、 2の画像 2
      • Remove all nine screws from the back of the device using a J0 bit.
      • Remove the small battery.
      FixBotに聞いてみる
      コメントを追加
    5. VTech InnoTab 2s Screen Replacement: 手順 5、 2の画像 1 VTech InnoTab 2s Screen Replacement: 手順 5、 2の画像 2
      • Using a plastic opening tool, detach the backplate from the front piece.
      • Do not use excessive force. Double check that you removed all the screws if the panel is not coming off easily.
      • Once the backplate has been removed, you will have access to the circuit board.
      FixBotに聞いてみる
      コメントを追加
    1. VTech InnoTab 2s Screen Replacement, Motherboard: 手順 6、 1の画像 1
      • First begin by removing the three cross-head screws using a J0 bit.
      FixBotに聞いてみる
      コメントを追加
    2. VTech InnoTab 2s Screen Replacement: 手順 7、 1の画像 1
      • First remove the ribbon cables. There are two highlighted by the red squares
      • Do not apply too much pressure and make sure that the black plastic tabs are fully open before you pull the cable out.
      FixBotに聞いてみる
      コメントを追加
    3. VTech InnoTab 2s Screen Replacement: 手順 8、 1の画像 1
      • Remove the camera from the assembly and put is a safe place so that it will not get damaged.
      FixBotに聞いてみる
      コメントを追加
    4. VTech InnoTab 2s Screen Replacement: 手順 9、 1の画像 1
      • Remove the board from the main assembly.
      • Be careful not to pull too hard so that the cables aren't broken.
      FixBotに聞いてみる
      コメントを追加
    5. VTech InnoTab 2s Screen Replacement: 手順 10、 1の画像 1
      • De-solder the points shown to fully remove the cables and free the board.
      • A soldering guide offered by IFIXIT can be found here Soldering Skills.
      FixBotに聞いてみる
      コメントを追加
    1. VTech InnoTab 2s Screen Replacement, Screen: 手順 11、 2の画像 1 VTech InnoTab 2s Screen Replacement, Screen: 手順 11、 2の画像 2
      • After removing the back plate and screws, all screws have been removed to separate the circuit board and wires from the front panel.
      • Remove the front panel from the device to expose the screen.
      FixBotに聞いてみる
      コメントを追加
    2. VTech InnoTab 2s Screen Replacement: 手順 12、 1の画像 1
      • Using a heat gun, heat the glue that holds the screen to the rest of the device.
      • While heating, carefully pull screen from the device exposing the ribbon wire on the back of the screen, disconnect.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Esthevan Romeiro
メンバー登録日: 10/06/16
261 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 5-1, Lacy Fall 2016 USF Tampa, Team 5-1, Lacy Fall 2016人のメンバー
USFT-LACY-F16S5G1
4 メンバー
48のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 27
今までの合計 1,181
