メインコンテンツにスキップ
VTech InnoTab 2S Headphone Jack Replacement
必要な工具と部品
  1. VTech InnoTab 2S Headphone Jack Replacement, Back Panel: 手順 1、 1の画像 1
    • Turn your device to where the back panel is facing you.
  2. VTech InnoTab 2S Headphone Jack Replacement: 手順 2、 2の画像 1 VTech InnoTab 2S Headphone Jack Replacement: 手順 2、 2の画像 2
    • Lift the Leg all the way up and twist the bottom to remove.
    • Once the bottom part pops out the whole leg should just come off.
    • Remove any game cartridge from the device.
  3. VTech InnoTab 2S Headphone Jack Replacement: 手順 3、 3の画像 1 VTech InnoTab 2S Headphone Jack Replacement: 手順 3、 3の画像 2 VTech InnoTab 2S Headphone Jack Replacement: 手順 3、 3の画像 3
    • Remove all of the plastic tabs on the device. These are covering screws that will need to be removed.
    • These covers are made of hard plastic so they may be difficult to remove.
    • There is a special tab in the cartridge cover that is made of rubber, make sure to not break this tab.
  4. VTech InnoTab 2S Headphone Jack Replacement: 手順 4、 2の画像 1 VTech InnoTab 2S Headphone Jack Replacement: 手順 4、 2の画像 2
    • Remove all nine screws from the back of the device using a J0 bit.
    • Remove the small battery.
  5. VTech InnoTab 2S Headphone Jack Replacement: 手順 5、 2の画像 1 VTech InnoTab 2S Headphone Jack Replacement: 手順 5、 2の画像 2
    • Using a plastic opening tool, detach the backplate from the front piece.
    • Do not use excessive force. Double check that you removed all the screws if the panel is not coming off easily.
    • Once the backplate has been removed, you will have access to the circuit board.
  6. VTech InnoTab 2S Headphone Jack Replacement, Motherboard: 手順 6、 1の画像 1
    • First begin by removing the three cross-head screws using a J0 bit.
  7. VTech InnoTab 2S Headphone Jack Replacement: 手順 7、 1の画像 1
    • First remove the ribbon cables. There are two highlighted by the red squares
    • Do not apply too much pressure and make sure that the black plastic tabs are fully open before you pull the cable out.
  8. VTech InnoTab 2S Headphone Jack Replacement: 手順 8、 1の画像 1
    • Remove the camera from the assembly and put is a safe place so that it will not get damaged.
  9. VTech InnoTab 2S Headphone Jack Replacement: 手順 9、 1の画像 1
    • Remove the board from the main assembly.
    • Be careful not to pull too hard so that the cables aren't broken.
  10. VTech InnoTab 2S Headphone Jack Replacement: 手順 10、 1の画像 1
    • De-solder the points shown to fully remove the cables and free the board.
    • A soldering guide offered by IFIXIT can be found here Soldering Skills.
  11. VTech InnoTab 2S Headphone Jack Replacement, Headphone Jack: 手順 11、 1の画像 1
    • First use the solderer tool to desolder the two points boxed in red on the image.
  12. VTech InnoTab 2S Headphone Jack Replacement: 手順 12、 1の画像 1
    この手順で使用する道具:
    購入する
    • Flip over the circuit board.
    • Using the metal tweezers, firmly grasp the headphone jack on either side and pull up to remove.
終わりに
作成者
4人の作成者と共同で作成されました。
Esthevan Romeiro
メンバー登録日: 10/06/16
261 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 5-1, Lacy Fall 2016 USF Tampa, Team 5-1, Lacy Fall 2016人のメンバー
USFT-LACY-F16S5G1
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 185
