メインコンテンツにスキップ
VTech InnoTab 2 Back Panel Replacement
必要な工具と部品
  1. VTech InnoTab 2 Back Panel Replacement, Battery: 手順 1、 3の画像 1 VTech InnoTab 2 Back Panel Replacement, Battery: 手順 1、 3の画像 2 VTech InnoTab 2 Back Panel Replacement, Battery: 手順 1、 3の画像 3
    • Apply slight pressure and slide the button above the battery cabinet to the right to open.
    • Remove battery cabinet cover by sliding away from the center of device.
    • This device requires 4AA batteries to function without the AC adaptor.
  2. VTech InnoTab 2 Back Panel Replacement, Back Panel: 手順 2、 3の画像 1 VTech InnoTab 2 Back Panel Replacement, Back Panel: 手順 2、 3の画像 2 VTech InnoTab 2 Back Panel Replacement, Back Panel: 手順 2、 3の画像 3
    • Remove all nine plastic caps from the back of the device using the plastic opening tool.
    • These covers are made of hard plastic so they may be difficult to remove.
  3. VTech InnoTab 2 Back Panel Replacement: 手順 3、 3の画像 1 VTech InnoTab 2 Back Panel Replacement: 手順 3、 3の画像 2 VTech InnoTab 2 Back Panel Replacement: 手順 3、 3の画像 3
    • Remove the hard rubber tab located by the cartridge slot using the plastic opening tool.
    • Be careful not to apply excessive force.
    • Once the rubber tab is removed unscrew the single 7 mm screw using a J0 screwdriver.
  4. VTech InnoTab 2 Back Panel Replacement: 手順 4、 2の画像 1 VTech InnoTab 2 Back Panel Replacement: 手順 4、 2の画像 2
    • Remove all ten 7mm screws from the back panel of the device using a JO bit screwdriver.
    • Do not use excessive force while removing the screws to prevent damaging the plastic case.
  5. VTech InnoTab 2 Back Panel Replacement: 手順 5、 2の画像 1 VTech InnoTab 2 Back Panel Replacement: 手順 5、 2の画像 2
    • Using the plastic opening tool, detach the back plate from the front piece.
    • Do not use excessive force. If the back plate does not gently come on double check that all screws were removed.
    • Once the back panel is removed, you will be able to see the motherboard and other components within the device.
終わりに
作成者
1人の作成者と共同作成されました。
Roberto Valdes
メンバー登録日: 10/18/17
302 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team S1-G85, Cagle Fall 2017 USF Tampa, Team S1-G85, Cagle Fall 2017人のメンバー
USFT-CAGLE-F17S1G85
2 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 12
今までの合計 413
