メインコンテンツにスキップ
VTech Baby's Learning Laptop Mouse Replacement
必要な工具と部品
  1. VTech Baby's Learning Laptop Mouse Replacement, Battery and Rear Panel: 手順 1、 1の画像 1
    • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Baby's Learning Laptop Mouse Replacement: 手順 2、 1の画像 1
    • Remove the battery door.
    • Take out the batteries.
  3. VTech Baby's Learning Laptop Mouse Replacement: 手順 3、 1の画像 1
    • Remove the rear panel screws using a Phillips #2 screwdriver.
    • Two 21.6mm (Long)
    • One 9.8mm (Short)
    • Five 13.8mm (Medium)
  4. VTech Baby's Learning Laptop Mouse Replacement: 手順 4、 2の画像 1 VTech Baby's Learning Laptop Mouse Replacement: 手順 4、 2の画像 2
    • Gently pull up on the rear panel.
    • Be careful not to pull on the wire connections.
    • Rest the laptop open on the table.
  5. VTech Baby's Learning Laptop Mouse Replacement, Mouse: 手順 5、 2の画像 1 VTech Baby's Learning Laptop Mouse Replacement, Mouse: 手順 5、 2の画像 2
    • Using a Phillips #0 screwdriver, remove the three 7.3mm screws.
  6. VTech Baby's Learning Laptop Mouse Replacement: 手順 6、 3の画像 1 VTech Baby's Learning Laptop Mouse Replacement: 手順 6、 3の画像 2 VTech Baby's Learning Laptop Mouse Replacement: 手順 6、 3の画像 3
    • Once the screws have been removed from the board, use a plastic opening tool to gently pry up the board and expose the mode switch assembly underneath.
    • Lay the board down gently and out of the way.
    • Take care not to damage any of the wires or the board itself.
  7. VTech Baby's Learning Laptop Mouse Replacement: 手順 7、 3の画像 1 VTech Baby's Learning Laptop Mouse Replacement: 手順 7、 3の画像 2 VTech Baby's Learning Laptop Mouse Replacement: 手順 7、 3の画像 3
    • Locate and remove the following screws:
    • Two 11.0mm Phillips #2.
    • Two 7.3mm Phillips #0.
    • Remove the top of the mouse which will separate from the under side once the screws are removed.
    • The metal connection near the yellow screws on the top left of the mouse assembly falls out very easily. Make sure to replace the metal connection with the prong pointing up. Otherwise, the mouse will not work correctly.
  8. VTech Baby's Learning Laptop Mouse Replacement: 手順 8、 2の画像 1 VTech Baby's Learning Laptop Mouse Replacement: 手順 8、 2の画像 2
    • Lift the springs up from the screw pegs with a plastic opening tool.
    • Remove the final part of the mouse.
    • Before reassembly, see the note on the previous step.
終わりに
作成者
5人の作成者と共同で作成されました。
Justin Schanze
メンバー登録日: 09/03/15
230 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 12-2, Blackwell Fall 2015 USF Tampa, Team 12-2, Blackwell Fall 2015人のメンバー
USFT-BLACKWELL-F15S12G2
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 4
今までの合計 1,005
