メインコンテンツにスキップ
VTech Baby's Learning Laptop Mode Switch Replacement
必要な工具と部品
  1. VTech Baby's Learning Laptop Mode Switch Replacement, Battery and Rear Panel: 手順 1、 1の画像 1
    • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Baby's Learning Laptop Mode Switch Replacement: 手順 2、 1の画像 1
    • Remove the battery door.
    • Take out the batteries.
  3. VTech Baby's Learning Laptop Mode Switch Replacement: 手順 3、 1の画像 1
    • Remove the rear panel screws using a Phillips #2 screwdriver.
    • Two 21.6mm (Long)
    • One 9.8mm (Short)
    • Five 13.8mm (Medium)
  4. VTech Baby's Learning Laptop Mode Switch Replacement: 手順 4、 2の画像 1 VTech Baby's Learning Laptop Mode Switch Replacement: 手順 4、 2の画像 2
    • Gently pull up on the rear panel.
    • Be careful not to pull on the wire connections.
    • Rest the laptop open on the table.
  5. VTech Baby's Learning Laptop Mode Switch Replacement, Mode Switch: 手順 5、 2の画像 1 VTech Baby's Learning Laptop Mode Switch Replacement, Mode Switch: 手順 5、 2の画像 2
    • Using a Phillips #0 screwdriver, remove the three 7.3mm screws.
  6. VTech Baby's Learning Laptop Mode Switch Replacement: 手順 6、 3の画像 1 VTech Baby's Learning Laptop Mode Switch Replacement: 手順 6、 3の画像 2 VTech Baby's Learning Laptop Mode Switch Replacement: 手順 6、 3の画像 3
    • Once the screws have been removed from the board, use a plastic opening tool to gently pry up the board and expose the mode switch assembly underneath.
    • Lay the board down gently and out of the way.
    • Take care not to damage any of the wires or the board itself.
  7. VTech Baby's Learning Laptop Mode Switch Replacement: 手順 7、 1の画像 1
    • Using a Phillips #0 screwdriver, remove the seven screws securing the mode switch assembly to the device.
    • Five 7.3mm
    • Two 6.0mm
  8. VTech Baby's Learning Laptop Mode Switch Replacement: 手順 8、 1の画像 1
    • Once the screws have been removed, the mode switch assembly can be removed easily.
    • Take care not to misplace the spring indicated in the picture.
    • You need this spring to find a matching replacement if it is in anyway damaged.
終わりに
作成者
3人の作成者と共同で作成されました。
Scott Parkinson
メンバー登録日: 09/09/15
107 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 12-2, Blackwell Fall 2015 USF Tampa, Team 12-2, Blackwell Fall 2015人のメンバー
USFT-BLACKWELL-F15S12G2
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 9
今までの合計 483
