はじめに
THe charging pin of the VIT P2402 represents a serious design flaw. It can move easily toward the inside of the chasis which can stop the laptop from charging properly.
必要な工具と部品
Place the laptop upside down, with the battery up.
Slide the security latch to the left.
Slide the security latch to the right with force
The second security latch ejects the battery from its place. Remove it.
Remove the six Phillips 00 screws that hold the service panel.
Remove the panel and clean it with a brush. Take special care in the slits and fan area.
Use a blower to remove dust from the fan. You must avoid turning this with pliers. The flow should be opposite to normal the normal circulation when the laptop is turned on. Use a small brush to loosen the dust.
Pull both retention hooks until the memory tilts.
Remove the memory
Pull the hard drive case so that you can move it to the left
Here we can see the SATA data and power connector.
Remove the 8 Phillips 00 screws from the inside chasis
Flip the laptop right-side up and use the tabs to remove the upper part of the the keyboard
Pull it slightly above the keyboard, enough to free the pegs from the inner part.
Tilt the keyboard from the inner part first. Free the ribbon cable from its two retainers.
Remove the ribbon cable that connects the motherboard to the touchpad
Lift the plastic retainer gently
Remove the ribbon cable from the upper part the same way. This connects to the power button.
Remove the two Phillips 00 screws
Remove the internal DVD unit
Remove the upper part of the chasis. Remove the powder from the other side.
Here we see the epoxy used to fix the charging pin, it can be used to prevent any contact.
Use an exacto knife to remove the excess epoxy.
Buenos dias, quiero aumentar la memoria ram de este modelo de vit, me podrian orientar un poco acerca de cual podria colocarle y hasta cuanta ram podria aumentarla? Gracias. Deivis.mantilla6@gmail.com
Saludos, segun recuerdo esta laptop usa memoria tipo DDR3. Potencialmente puede llegar a 8GB o incluso 16GB. Pero hay forma de asegurarse instalando una aplicación que indica el tipo de memoria. Me puede contactar por twitter o por otras RRSS si revisa mi perfil de iFixit para guiarlo con la aplicación.
que chipset tiene la placa? para saber que procesadores soporta para upgrade.
Saludos, chipset HM76.
Con lo cual, sería compatible con la 2da y 3era generación, con socket FCPGA988. Esto según: https://vitsdata.blogspot.com/2018/01/eq...
Excelente explicación muy detallada y buena gracias
hola no se si vea esto pero si lo hace me podria decir si en el chip de video trae discipador?,compre una de ese modelo y no lo trajo y se me apaga,quiero saber si es por eso muchas gracias
Para volver a montar tu aparato, siga estas instrucciones en orden inverso.
14 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
40 件のコメント
Saludos Marcos Saludos estas vit p2402 poseen en el circuito de encendido un componente SMD de numeración X315, podrias por favor ayudarme a identificar que cosa es y cual es su funcion, pues al parecer me esta presentando problemas y necesita ser reemplazado, pero eso no sale como transistor, no es un simple mosfet, no es un regulador termico, ni de carga,no es diodo, que cosa es? y sobre todo, en caso de no conseguirlo, con que se puede sustituir este componente.
Saludo Miguel.
Veo que en google no sale ese componente. Lo que hice con la laptop de la guía fue cambiar el pin de carga por otro haciendo un corte y tape negro. sin embargo, me puedes contactar si pinchas mi perfil de ifixit, verás mi redes sociales.
hola me gustaria que me orienten, mi lapto vit p2402 no prende devido a que tuvo un corto circuito y se le quemo una fuente. la pieza dañada es i225al2v. la pregunta es puedo sustituir esa pieza y lograr de alguna manera que funcione con normalidad.
Saludos. No tengo como ayudarte en eso ya que por ahora no tengo el conocimiento de electrónica y microsoldadura necesario.
Si se te ofrece otra cosa, puedes contactarme por mis RRSS que aparecen en mi perfil de ifixit.
Amigo no sabes que modelo es el pin de carga para poder reemplazarlo… Gracias
Es muy difícil responder a eso, esos pines no tiene códigos que uno pueda identificar para buscar. A veces lo nombran según el diámetro, medido en milímetros, pero varios modelos incompatibles coinciden en ese número.
Recomiendo es sacar el pin malo y llevarlo como muestra a diferentes tiendas y vendedores a ver quien te vende un reemplazo que coincida.
Cualquier cosa, me puedes contactar en mis RRSS de mi perfil de ifixit.
Amigo te escribo porque mi laptop vit p2402 la misma est encendida trabajando un buen tiempo ,puede que una semana o 5 días y de un momento a otro esta se apaga y pasan 2 minutos y la enciendes y no reconoce el disco pero la dejas reposar 5 o 10 minutos y enciende y reconoce el disco y escapas de trabajar 3 o 4 horas más y en este período de tiempo se vuelve a apagar y así seguidamente y el error que da es error de disco pero no creo que sea el disco porque ya le cambiado 2 discos e incluso 1no de estos lo puse a trabajar en otra laptop y hoy en gia sigue trabajando ( que puedes orientar que sea este problema) y las memorias RAM son nuevas las cambie pensando que este era el problema, porque un amigo me lo sugirió.
Alex Yera Ortiz
Saludos Alex, eso suena en parte a un problema térmico, has probado limpiar las aspas del ventilador? para una consulta más detallada puedes contactarme en mis RRSS que están en mi perfil de ifixit.
Hola Marcos,
Un cordial saludo.
Tengo una VIT 3400-01 y quiero reemplazar la batería y el ventilador del procesador pero no sé cómo buscar las piezas.
Gracias de antemano.
si mal no recuerdo esa laptop usa una batería “rectangular, plana, interna” en lugar de las tradicionales que se extraen con facilidad. No es fácil de conseguir un reemplazo porque es casi obligatorio que te lo vendan como repuesto de otra (una laptop “donante”) que estén en peores condiciones y venden las partes como repuesto. Cualquier cosa, puedes contactarme a mis RRSS en mi perfil de ifixit.
Buenas tardes, Amigo necesito el manual de dicha tarjeta madre para identificar siertas cosas en ella, Sabes donde encontrarla ya que no la e podido encontrar. Gracias
Saludos, he intentado conseguir el manual, pero no aparece. Lo único que no he intentado es ponerme en contacto con la empresa VIT. Podrías intentar eso. De resto, puedes contactarme en mis RRSS que están en mi perfil de ifixIT
hola buenas noches Marcos, tengo una p2402 y quiero hacerle una ampliación de Ram, y queria saber si me guantaria un nodulo de 8 gs de ram o si seria mejor comprar dos de 4 una para cada solts?
El máximo de RAM que soporta esta laptop depende del CPU, porque el chip controlador de memoria viene en él, tendrías que decirme cual es o investigar por tu cuenta. Sin embargo, también es posible que la placa base lo limite de alguna forma, por eso no me arriesgo a decir un “si” tajante. Necesariamente hay que probar 2 DIMM de 8GB cada uno para asegurarlo (yo tengo un par de esos que uso para trabajo, parar probar pues). Me puedes contactar a mi twitter que aparece en mi perfil de Ifixit.
Hola, tengo una laptop Vit P2402, se le hundió el pin de carga, hay que sustituirlo por uno nuevo o hay alguna manera de llevarlo a su lugar?
Si el pin aún suministra corriente y no se apaga con pequeños movimientos, pues debería poderse arreglar así: se corta un taco de madera que empuje el pin en su lugar (ver paso 9) para que no se “se hunda”. Lo que yo hice con la laptop finalmente fue sustituir el pin por otro, pero es que el original estaba malo. (esto no aparece en la guia, fue después). Al nuevo pin le alargué el cable y queda “afuera” de la laptop, así no hay forma de que se hunda. Funciona muy bien.
Muchas gracias por la información, puede desarmar y armar la laptop sin problemas y reparar el pin de carga.
Saludos
Que bueno que pudiste, cualquier duda, puedes escribirme en twitter o instagram. En mi perfil de IFixIt salen.
Hola Marcos, muy buena tu guía. Tengo un modelo igual, pero no me funciona la cámara, es como si estuviera desconectada. Tienes alguna idea de cuál es el conector de la cámara? Saludos
Saludos, no puedo decir con seguridad, pero en el paso 5 hay una flex largo debajo del teclado, en la parte cercana a la pantalla, puede ser ese. Puedes contactarme en mis RRSS que aparecen en mi perfil de ifixit.
Saludos… tengo una VIT P2402… con el cargador ella funciona bien pero cuando se va la energía eléctrica, o quiero trabajarla sin el regulador no funciona… Ya revisé la batería y está buena… Para saber si es algún componente en particular o es el Ping de carga…
Si me pueden orientar para ver si tiene solución o no esta falla…..
Gracias de antemano
hola marcos, excelente manual. quiero felicitarte por tan buen material y por tomarte tu tiempo en responder las preguntas de todas las personas que por aca te contactan. el motivo del presente comentario aparte de saludarte, felicitarte y agradecerte es para que orientes con un problemilla con una laptop vit p2400, el problema es que no me quiere iniciar ningun window ya sea de 32 o 64 bits. todos los que instalo quedan en el logo. he probado con varios discos duros y he cambiado la memoria ram, pero si instalo algun sistema linux arranca sin problemas de hecho estoy usando ubuntu y trabaja sin problemas. gracias de antemano por cualquier recomendacion
Saludos… Me gustaría saber si el procesador de esta laptop es reemplazable. Tengo entendido que es rPGA y que puede ser cambiado por un i5 3210m. Quisiera saber si se puede cambiar o si está soldado
Buenas tardes Marcos, tengo una Vit M2400, y el teclado ha empezado a dañarse es decir a dejar de marcar ciertas teclas, que se puede hacer en ese caso?
Buenas me puedes orientar. Para ver si es posible aumentarle la cantidad de memoria dedicada al Video en la vit p2402 . Ya qe tiene muy poca.
Hola amigo quisiera saber cómo le coloco a mi laptop vit las cintas de audio, del touchpa y la de encendido ya que no logro colocarlas
Bd, se le puede colocar una Ram de 8 GB de una sola pieza o deben ser 2 de 4 GB
Hola Marcos tengo un problema con una Lapto P2402 que me dio pantalla azul en el sistema windows 10. y no pude recuperar el sistemma.
tratando de solucionar desconfigure parte de la bios y ahora en el boot no me senala el DD para montarle un sistema operativo, para arrancarla desde una unidad de USB.
Mi laptop se prende el bombillo de la batería, cambia de color azul a rojo; conecto el cargador y sigue cambiando de azul a rojo…
saludos , estoy buscando la bateria de la vit p2402 no sabes donde la consigo o de otra bateria que se le pueda adactar ya que esas estan es casas si tienes alguna información por favor indícame que puedo hacer gracias
Hola MARCO quisiera que me orientes yo estoy buscando una batería para la laptop p2402 si sabes donde puedo conseguirla o si sabes también de si se le puede adaptar otra por favor avísame si tienes alguna información
Hola marco no contestaste mi pregunta por si tienes conocimientos dr que si hay otras baterías qie le hagan a la vitp o donde puedo encontrar una de vitp porfa avisame o si tu puedes conseguirla gracias
Buenos noches me podrían decir dónde puedo comprar el pin de carga de la PC VIT P2402?
Gracias
Hermano, tengo un problema de carga que se refleja en la parálisis del teclado, la pantalla y por supuesto en el arranque de la Vit 2402 laptop, puedes indicarme las incidencias del mal uso de la carga de la bateria… Hay un componente que se interrumpe y no permite que abra el sistema operativo,por ende el teclado, la pantalla, el tactil, la cáma, ni el audio, demas de los puertos USB, de monitor externo, Lan, ect… …¿qué puedo hacer ? ezequieljosé… mi e-mail.. ezequiel 748@gmail.com
Buenas se puede remplazar el fan cooler de una laptop vip p2402 se le podria adaptar otro?
Hola amigo tengo una vit 2402 y tengo un problema cada 30 minutos se apaga sola así este conectada ya le hice mantenimiento y le cambie la pasta térmica y aún sigue el problema, que puede ser ?
saludos, por favor podria indicarme que marca o fabricante y modelo es la tarjeta madre de la laptop vit p2402?
buenas amigo crees que me puedas ayudar tengo una vit p2423 y quisiera saber como desarmarla que quisiera saber como quitar el lector de discos y colocarle un adactador para disco duros
