この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Here we will be removing the small michrophone in the back of the taco. This task requires removing the logic board before it may be reached.
必要な工具と部品
Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
この手順で使用する道具:Phillips #0 Screwdriver$5.49
Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
Below the logic board, the small black microphone is resting within the case.
ある他の人がこのガイドを完成しました。
