メインコンテンツにスキップ
VENSTAR Taco Logic Board Replacement Replacement
必要な工具と部品
  1. VENSTAR Taco Logic Board Replacement Replacement, VENSTAR Taco Disassembly: 手順 1、 3の画像 1 VENSTAR Taco Logic Board Replacement Replacement, VENSTAR Taco Disassembly: 手順 1、 3の画像 2 VENSTAR Taco Logic Board Replacement Replacement, VENSTAR Taco Disassembly: 手順 1、 3の画像 3
    • Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
    • The base labeled "VENSTAR TACO" is glued. Be careful separating the two sides of the device.
  2. VENSTAR Taco Logic Board Replacement Replacement: 手順 2、 2の画像 1 VENSTAR Taco Logic Board Replacement Replacement: 手順 2、 2の画像 2
    • Repeat the previous step on the opposite side to remove the other outer casing.
    • Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
    • The screws are small and can get stuck. Use tweezers to pull them out if you are having trouble.
  3. VENSTAR Taco Logic Board Replacement Replacement: 手順 4、 2の画像 1 VENSTAR Taco Logic Board Replacement Replacement: 手順 4、 2の画像 2
    • From the same side you just unscrewed, use a plastic opening tool to unwedge the inner cover on both sides of the base.
  4. VENSTAR Taco Logic Board Replacement Replacement: 手順 5、 2の画像 1 VENSTAR Taco Logic Board Replacement Replacement: 手順 5、 2の画像 2
    • Slide off the inner cover. It pulls apart and is held on by a small amount of glue.
  5. VENSTAR Taco Logic Board Replacement Replacement, Logic Board Replacement: 手順 6、 1の画像 1
    • Remove the rubber covering from the buttons.
  6. VENSTAR Taco Logic Board Replacement Replacement: 手順 7、 3の画像 1 VENSTAR Taco Logic Board Replacement Replacement: 手順 7、 3の画像 2 VENSTAR Taco Logic Board Replacement Replacement: 手順 7、 3の画像 3
    • Remove the black fabric covering the logic board.
  7. VENSTAR Taco Logic Board Replacement Replacement: 手順 8、 2の画像 1 VENSTAR Taco Logic Board Replacement Replacement: 手順 8、 2の画像 2
    • Move the battery out of the way of the connector.
  8. VENSTAR Taco Logic Board Replacement Replacement: 手順 9、 2の画像 1 VENSTAR Taco Logic Board Replacement Replacement: 手順 9、 2の画像 2
    • Undo the connector of the flat white ribbon between the switches and the logic board.
  9. VENSTAR Taco Logic Board Replacement Replacement: 手順 10、 1の画像 1
    • Undo the two black 3mm screws on the logic board using the PH0 screwdriver.
  10. VENSTAR Taco Logic Board Replacement Replacement: 手順 11、 3の画像 1 VENSTAR Taco Logic Board Replacement Replacement: 手順 11、 3の画像 2 VENSTAR Taco Logic Board Replacement Replacement: 手順 11、 3の画像 3
    • Gently pull out the logic board.
    • Note that the battery and the logic board are connected and must be removed together.
終わりに
作成者
3人の作成者と共同で作成されました。
Kaylee Simms
メンバー登録日: 01/30/16
310 ポイント
3のガイドは作成済み
チーム
University of Kentucky Louisville, Team 1-3, Matravers Spring 2016 University of Kentucky Louisville, Team 1-3, Matravers Spring 2016人のメンバー
LOUISVILLE-MATRAVERS-S16S1G3
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 290
