メインコンテンツにスキップ
Uninstalling an Electric Water Heater
必要な工具と部品
  1. Uninstalling an Electric Water Heater, Water Heater: 手順 1、 1の画像 1
    • At the breaker box, locate the breaker for the water heater. Switch the breaker bar to the off position.
    • Using a multimeter, check the line voltage at the water heater. The multimeter should read "0 VAC."
  2. Uninstalling an Electric Water Heater: 手順 2、 2の画像 1 Uninstalling an Electric Water Heater: 手順 2、 2の画像 2
    • Using a Phillips #0 screwdriver, remove the access panel (or panels) to access the thermostat and element.
    • Some electric water heater models may have only one access panel, located near the bottom of the tank. Some may have two— both an upper and lower access panel.
    • Set aside the access panel cover and screws. Remove the insulation to expose the wires, thermostat, and element.
    • Disconnect the wiring from the electrical components in the panel.
  3. Uninstalling an Electric Water Heater, Draining the tank: 手順 4、 1の画像 1
    • Attach a hose to the drain valve located at the bottom of the tank, near the lower access panel. Place the other end of the hose in a safe location for the water to drain.
    • Open the drain valve on the water heater by turning it counter-clockwise.
    • Once you have a steady flow of water coming out of the hose, slowly close the cold water valve to the water heater by turning it clockwise.
    • If the water flow slows down, you can open a sink or tub faucet to help the tank drain quicker.
  4. Uninstalling an Electric Water Heater: 手順 5、 1の画像 1
    • Using adjustable pliers, disconnect the water lines from the tank.
    • If the lines are glued in place, you will need to use a steel wire saw to disconnect the water line.
  5. Uninstalling an Electric Water Heater: 手順 6、 2の画像 1 Uninstalling an Electric Water Heater: 手順 6、 2の画像 2
    • Using a pipe wrench, detach all remaining pipes from the tank.
  6. Uninstalling an Electric Water Heater: 手順 7、 1の画像 1
    • Remove the water tank.
    • The tank will have sediment and some water in it. It will be heavy and require at least 2 people to move it safely.
    • To install a new water heater, follow the manufacturer's installation instructions included with the new appliance.
終わりに
To install a new water heater, follow the manufacturer’s installation instructions provided with the new water heater.
2 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Lindsay Martin
メンバー登録日: 09/20/17
178 ポイント
1ガイドが承認済み
チーム
Pasco Hernando, Team S4-G11, Prince Winter 2017 Pasco Hernando, Team S4-G11, Prince Winter 2017人のメンバー
PHSC-PRINCE-W17S4G11
1 メンバー
1のガイドは作成済み
1件のガイドコメント
If you have enough assistance to transport the unit outside the house, taking apart an old water heater is simple. Components, mounting hardware, and other aspects of a water heater can all be removed independently. Nonetheless, it takes strength to pull the old water from its place and move it outside for proper disposal.
Juliet Cyrus - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 15
過去 30 日: 69
今までの合計 5,670
