メインコンテンツにスキップ
Uniden TCX905 Circuit Board Replacement
必要な工具と部品
  1. Uniden TCX905 Circuit Board Replacement, Battery Cover: 手順 1、 2の画像 1 Uniden TCX905 Circuit Board Replacement, Battery Cover: 手順 1、 2の画像 2
    • Starting from the top of the cover, slide down and away from the phone with your thumb
    • Lift battery cover off of batter and place it to the side
  2. Uniden TCX905 Circuit Board Replacement, Battery Pack: 手順 2、 2の画像 1 Uniden TCX905 Circuit Board Replacement, Battery Pack: 手順 2、 2の画像 2
    • Once battery cover is removed, place your thumb and index fingers on the the wires near the receptacle
    • Gently pull straight up on the wires until a click is heard which signifies the battery is completely disconnected
    • Place battery pack to the side
  3. Uniden TCX905 Circuit Board Replacement, Back Shell: 手順 3、 2の画像 1 Uniden TCX905 Circuit Board Replacement, Back Shell: 手順 3、 2の画像 2
    • Remove the two 11mm screws inside the battery storage compartment using Phillips #1 screwdriver (located near the very bottom of the phone)
  4. Uniden TCX905 Circuit Board Replacement: 手順 4、 3の画像 1 Uniden TCX905 Circuit Board Replacement: 手順 4、 3の画像 2 Uniden TCX905 Circuit Board Replacement: 手順 4、 3の画像 3
    • Gently open phone casing along the seam at the bottom of the phone using index and middle fingers of both hands
  5. Uniden TCX905 Circuit Board Replacement: 手順 5、 3の画像 1 Uniden TCX905 Circuit Board Replacement: 手順 5、 3の画像 2 Uniden TCX905 Circuit Board Replacement: 手順 5、 3の画像 3
    • Ensure that wired connection between circuit board and back shell is not strained
    • Fold the back shell underneath the front shell and circuit board
  6. Uniden TCX905 Circuit Board Replacement, Circuit Board: 手順 6、 2の画像 1 Uniden TCX905 Circuit Board Replacement, Circuit Board: 手順 6、 2の画像 2
    • Carefully remove the middle two 7mm screws, the outer top 9mm screws, and the top middle 7 mm screw that hold the logic board to the front shell of the phone casing using the Phillips #1 screwdriver
  7. Uniden TCX905 Circuit Board Replacement: 手順 7、 3の画像 1 Uniden TCX905 Circuit Board Replacement: 手順 7、 3の画像 2 Uniden TCX905 Circuit Board Replacement: 手順 7、 3の画像 3
    • Using index finger and thumb, carefully remove the circuit board from the front shell of phone
終わりに
作成者
3人の作成者と共同で作成されました。
Gary Pence
メンバー登録日: 03/26/14
807 ポイント
8のガイドは作成済み
チーム
Clemson, Team 1-1, Benson Spring 2014 Clemson, Team 1-1, Benson Spring 2014人のメンバー
CLEM-BENSON-S14S1G1
3 メンバー
16のガイドは作成済み
2件のガイドコメント
I liveI at Buenos Aires, Argentina. I need to repaire a Uniden TCX905 Circuit Board and I wish to receive the manual for repaire, if it existe. Thanks in advance . Ruben E. (zrubene@gmail.com)
zrubene - 返信
Where can one get a TCX905 replacement circuit board?
greywing - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 19
今までの合計 1,079
