メインコンテンツにスキップ
Uniden TCX905 Back Speaker Replacement
必要な工具と部品
  1. Uniden TCX905 Back Speaker Replacement, Battery Cover: 手順 1、 2の画像 1 Uniden TCX905 Back Speaker Replacement, Battery Cover: 手順 1、 2の画像 2
    • Starting from the top of the cover, slide down and away from the phone with your thumb
    • Lift battery cover off of batter and place it to the side
  2. Uniden TCX905 Back Speaker Replacement, Battery Pack: 手順 2、 2の画像 1 Uniden TCX905 Back Speaker Replacement, Battery Pack: 手順 2、 2の画像 2
    • Once battery cover is removed, place your thumb and index fingers on the the wires near the receptacle
    • Gently pull straight up on the wires until a click is heard which signifies the battery is completely disconnected
    • Place battery pack to the side
  3. Uniden TCX905 Back Speaker Replacement, Back Shell: 手順 3、 2の画像 1 Uniden TCX905 Back Speaker Replacement, Back Shell: 手順 3、 2の画像 2
    • Remove the two 11mm screws inside the battery storage compartment using Phillips #1 screwdriver (located near the very bottom of the phone)
  4. Uniden TCX905 Back Speaker Replacement: 手順 4、 3の画像 1 Uniden TCX905 Back Speaker Replacement: 手順 4、 3の画像 2 Uniden TCX905 Back Speaker Replacement: 手順 4、 3の画像 3
    • Gently open phone casing along the seam at the bottom of the phone using index and middle fingers of both hands
  5. Uniden TCX905 Back Speaker Replacement: 手順 5、 3の画像 1 Uniden TCX905 Back Speaker Replacement: 手順 5、 3の画像 2 Uniden TCX905 Back Speaker Replacement: 手順 5、 3の画像 3
    • Ensure that wired connection between circuit board and back shell is not strained
    • Fold the back shell underneath the front shell and circuit board
  6. Uniden TCX905 Back Speaker Replacement, Back Speaker: 手順 6、 2の画像 1 Uniden TCX905 Back Speaker Replacement, Back Speaker: 手順 6、 2の画像 2
    • Lay the back shell with the inside facing up
    • To remove the speaker guard, first remove the 7mm screw from inside the back shell
  7. Uniden TCX905 Back Speaker Replacement: 手順 7、 3の画像 1 Uniden TCX905 Back Speaker Replacement: 手順 7、 3の画像 2 Uniden TCX905 Back Speaker Replacement: 手順 7、 3の画像 3
    • To access the speaker, flip the back shell over and use a plastic opening tool to pop open the black cover
    • Gently push the speaker guard out of place with your thumb
    • Carefully slide the speaker out from its setting and place speaker guard aside
  8. Uniden TCX905 Back Speaker Replacement: 手順 8、 2の画像 1 Uniden TCX905 Back Speaker Replacement: 手順 8、 2の画像 2
    • With speaker exposed, remove the speaker by cutting the red and black wires near their contact location
終わりに
作成者
4人の作成者と共同で作成されました。
Gary Pence
メンバー登録日: 03/26/14
807 ポイント
8のガイドは作成済み
チーム
Clemson, Team 1-1, Benson Spring 2014 Clemson, Team 1-1, Benson Spring 2014人のメンバー
CLEM-BENSON-S14S1G1
3 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 331
