はじめに
The TCX905 consists of a two part shell. The back shell is where the battery and back speaker are, the front shell includes the buttons and the screen.
必要な工具と部品
Starting from the top of the cover, slide down and away from the phone with your thumb
Lift battery cover off of batter and place it to the side
Once battery cover is removed, place your thumb and index fingers on the the wires near the receptacle
Gently pull straight up on the wires until a click is heard which signifies the battery is completely disconnected
Place battery pack to the side
Remove the two 11mm screws inside the battery storage compartment using Phillips #1 screwdriver (located near the very bottom of the phone)
ある他の人がこのガイドを完成しました。
