1. Refer to the Uniden EXP 371 phone disassembly guide to open the plastic casing.
    • Refer to the Uniden EXP 371 phone disassembly guide to open the plastic casing.
  2. Use the Phillips #1 screwdriver to unscrew the screws located at the bottom left and right hand corners and top of the phone; as shown in the image. Use the Phillips #1 screwdriver to unscrew the screws located at the bottom left and right hand corners and top of the phone; as shown in the image. Use the Phillips #1 screwdriver to unscrew the screws located at the bottom left and right hand corners and top of the phone; as shown in the image.
    • Use the Phillips #1 screwdriver to unscrew the screws located at the bottom left and right hand corners and top of the phone; as shown in the image.
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Remove the motherboard once the screws holding it in place are undone. Once the motherboard has been removed, remove the rubber button pad located behind the motherboard and in front of the dial pad.
    • Remove the motherboard once the screws holding it in place are undone.
    • Once the motherboard has been removed, remove the rubber button pad located behind the motherboard and in front of the dial pad.
  5. After the rubber pad is removed remove the dial pad (buttons) from the phone.
    • After the rubber pad is removed remove the dial pad (buttons) from the phone.
  6. If the buttons are sticky; leaving the dial pad and/or rubber pad to soak in soap and water for 5-10 minutes will clean off any sticky residue that may be obstructing the buttons. Make sure to properly dry the dial pad and rubber pad of any soap/water before reattaching them to the phone to avoid the risk of short circuiting.
    • If the buttons are sticky; leaving the dial pad and/or rubber pad to soak in soap and water for 5-10 minutes will clean off any sticky residue that may be obstructing the buttons.
    • Make sure to properly dry the dial pad and rubber pad of any soap/water before reattaching them to the phone to avoid the risk of short circuiting.
  7. If sticky residue is not the problem the next step is to visit http://udn.factoryoutletstore.com and search for the UNIDEN EXP 371 and order a new dial pad.
まとめ
Lucas Mohsen
メンバー登録日: 2014年10月31日
101 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 2-1, Duarte Fall 2014 UMass Dartmouth, Team 2-1, Duarte Fall 2014人のメンバー
UMASSD-DUARTE-F14S2G1
4 メンバー
5のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 84
