メインコンテンツにスキップ
Uniden EXP 371 Antenna Replacement
必要な工具と部品
  1. Uniden EXP 371 Antenna Replacement, Uniden EXP 371 Teardown: 手順 1、 1の画像 1
    • Uniden EXP371 900 MHz Cordless Phone.
    • 900 MHz Extended Range with One Touch RocketDial/Find Handset Locator and is Desk or Wall Mountable.
  2. Uniden EXP 371 Antenna Replacement: 手順 2、 2の画像 1 Uniden EXP 371 Antenna Replacement: 手順 2、 2の画像 2
    • Remove the battery by first pressing down on the rear of the cover and pushing the cover towards the bottom of the phone.
    • Next remove the battery by pulling on the connector.
  3. Uniden EXP 371 Antenna Replacement: 手順 3、 2の画像 1 Uniden EXP 371 Antenna Replacement: 手順 3、 2の画像 2
    • Next remove the two screws at the bottom of the phone with a PH1 philips screwdriver.
    • Now remove the top portion of the case from the bottom. This may be difficult to do with your bare hands. The use of a plastic opening tool may come in handy.
  4. Uniden EXP 371 Antenna Replacement: 手順 4、 3の画像 1 Uniden EXP 371 Antenna Replacement: 手順 4、 3の画像 2 Uniden EXP 371 Antenna Replacement: 手順 4、 3の画像 3
    • Your next step is to remove the five screws holding down the motherboard. Use the PH1 philips screwdriver.
    • Once you have removed the five screws you may lift the motherboard off of the front case.
    • At this point you may also remove the dial pad. It simply lifts off.
    • You may also remove the speaker if needed by unscrewing the two screws using the PH1 philips screwdriver.
    • The whole phone is now disassembled at this point.
  5. Uniden EXP 371 Antenna Replacement, Antenna: 手順 5、 2の画像 1 Uniden EXP 371 Antenna Replacement, Antenna: 手順 5、 2の画像 2
    • After following the teardown guide. Take the bottom case and locate the antenna at the top of the phone.
    • Lift the bottom of the the antenna with the aid of a tool (these tweezers work well) and push the antenna inside the phone to remove it.
    • To reassemble the phone, follow the steps in the reverse order.
終わりに
作成者
2人の作成者と共同で作成されました。
Eric Rodrigues
メンバー登録日: 10/16/14
343 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 2-1, Duarte Fall 2014 UMass Dartmouth, Team 2-1, Duarte Fall 2014人のメンバー
UMASSD-DUARTE-F14S2G1
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 1,257
