メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Uniden Dect 6.0 Keyboard Replacement
必要な工具と部品
  1. Uniden Dect 6.0 Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • Locate the battery compartment on the back of the Uniden home phone.
    • Place your finger on the groove, and pull directly back on the cover to access to the battery.
  2. Uniden Dect 6.0 Keyboard Replacement: 手順 2、 1の画像 1
    • Remove the white battery pack from the battery compartment.
  3. Uniden Dect 6.0 Keyboard Replacement: 手順 3、 1の画像 1
    • Remove the red-and-black-wired port from the plug directly under the battery compartment.
  4. Uniden Dect 6.0 Keyboard Replacement, Keyboard: 手順 4、 2の画像 1 Uniden Dect 6.0 Keyboard Replacement, Keyboard: 手順 4、 2の画像 2
    • Using a Phillips #1 screwdriver, remove the two .9 mm screws on the back of the device on each side of the battery pack.
  5. Uniden Dect 6.0 Keyboard Replacement: 手順 5、 1の画像 1
    • Using your fingers, gently lift and separate the front of the housing from the back housing.
    • Potential for device damage: While separating the back housing from the front, be sure to open from the sides as pictured.
  6. Uniden Dect 6.0 Keyboard Replacement: 手順 6、 1の画像 1
    • Gently remove the loose keyboard from the lined gel casing located under the front housing of the front of the phone.
終わりに
ある他の人がこのガイドを完成しました。
作成者
7人の作成者と共同で作成されました。
Megan Lawrence
メンバー登録日: 01/14/15
534 ポイント
5のガイドは作成済み
チーム
USF Sarasota-Manatee, Team 1-3, Stewart Winter 2015 USF Sarasota-Manatee, Team 1-3, Stewart Winter 2015人のメンバー
USFSM-STEWART-W15S1G3
4 メンバー
18のガイドは作成済み
1件のガイドコメント
Great to have this guide! I’d add that (at least on my aging handset). Prying it open can feel a bit sketchy cause it may resist a bit, so I used the metal spudger to go around the edge lifting the tabs. But the plastic on these is pretty great and will not break even puting some force on it.
Also be mindful of the speaker on the back which is connected to the front case.
Ivan Viales - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 43
今までの合計 3,780
