メインコンテンツにスキップ
Uniden Dect 6.0 Display Replacement
必要な工具と部品
  1. Uniden Dect 6.0 Display Replacement, Battery: 手順 1、 1の画像 1
    • Locate the battery compartment on the back of the Uniden home phone.
    • Place your finger on the groove, and pull directly back on the cover to access to the battery.
  2. Uniden Dect 6.0 Display Replacement: 手順 2、 1の画像 1
    • Remove the white battery pack from the battery compartment.
  3. Uniden Dect 6.0 Display Replacement: 手順 3、 1の画像 1
    • Remove the red-and-black-wired port from the plug directly under the battery compartment.
  4. Uniden Dect 6.0 Display Replacement, Keyboard: 手順 4、 2の画像 1 Uniden Dect 6.0 Display Replacement, Keyboard: 手順 4、 2の画像 2
    • Using a Phillips #1 screwdriver, remove the two .9 mm screws on the back of the device on each side of the battery pack.
  5. Uniden Dect 6.0 Display Replacement: 手順 5、 1の画像 1
    • Using your fingers, gently lift and separate the front of the housing from the back housing.
    • Potential for device damage: While separating the back housing from the front, be sure to open from the sides as pictured.
  6. Uniden Dect 6.0 Display Replacement: 手順 6、 1の画像 1
    • Gently remove the loose keyboard from the lined gel casing located under the front housing of the front of the phone.
  7. Uniden Dect 6.0 Display Replacement, Gel Casing: 手順 7、 1の画像 1
    • To better access the screen, remove the loose gel casing that sits under the keyboard.
  8. Uniden Dect 6.0 Display Replacement: 手順 8、 1の画像 1
    • Lift out the attached motherboard piece and turn it sideways to access the side of the phone.
    • Potential for device damage: Use caution to avoid severing the wires that connect the motherboard to the phone.
  9. Uniden Dect 6.0 Display Replacement: 手順 9、 1の画像 1
    • Gently use the tweezers to access the motherboard panel and lift it straight up.
終わりに
3 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Megan Lawrence
メンバー登録日: 01/14/15
534 ポイント
5のガイドは作成済み
チーム
USF Sarasota-Manatee, Team 1-3, Stewart Winter 2015 USF Sarasota-Manatee, Team 1-3, Stewart Winter 2015人のメンバー
USFSM-STEWART-W15S1G3
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 26
今までの合計 6,204
