はじめに
Over time, the rechargeable battery in your Uniden DECT 6.0 phone may lose its ability to properly hold a charge. This rechargeable battery powers your cordless phone and allows it to operate wirelessly when removed from the charging base. When the battery loses capacity, it can cause symptoms of quickly drained battery after charging, frequent low battery warnings, or phone may not turn on at all. Fortunately for you, replacing the battery is a quick and simple process that can restore your phone's ability. This guide will provide you step-by-step instructions on how to safely remove the old battery and install a new one. Please note that you will need a compatible battery replacement before starting.
必要な工具と部品
Locate the battery compartment on the back of the Uniden home phone.
Place your finger on the groove, and pull directly back on the cover to access to the battery.
4 の人々がこのガイドを完成させました。
3件のガイドコメント
What type of battery do I need?
I was given a Uniden homephone cordless DECT 6 but it has no battery in it. How do I know what battery to buy?
Karen Barnes - 返信 共有
