メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Uniden D1483-3BK Circuit Board/Screen Replacement
必要な工具と部品
  1. Uniden D1483-3BK Circuit Board/Screen Replacement, Battery: 手順 1、 1の画像 1
    • Set the phone with dial keys facing downward.
  2. Uniden D1483-3BK Circuit Board/Screen Replacement: 手順 2、 2の画像 1 Uniden D1483-3BK Circuit Board/Screen Replacement: 手順 2、 2の画像 2
    • Slide the battery cover toward the bottom of the phone.
    • Lift and remove the back cover from the phone.
  3. Uniden D1483-3BK Circuit Board/Screen Replacement: 手順 3、 1の画像 1
    • Remove the battery from its compartment.
    • Pinch the end of cord where the battery is attached to the phone and pull up gently.
  4. Uniden D1483-3BK Circuit Board/Screen Replacement, Handset Case: 手順 4、 2の画像 1 Uniden D1483-3BK Circuit Board/Screen Replacement, Handset Case: 手順 4、 2の画像 2
    • Remove the two 9mm Phillips #1 screws in the battery compartment.
  5. Uniden D1483-3BK Circuit Board/Screen Replacement: 手順 5、 3の画像 1 Uniden D1483-3BK Circuit Board/Screen Replacement: 手順 5、 3の画像 2 Uniden D1483-3BK Circuit Board/Screen Replacement: 手順 5、 3の画像 3
    • Use the plastic opening tool to carefully separate the two halves of the case.
    • Slowly work around the entire case to fully separate the halves before pulling them apart.
    • Wires inside the case hold the two halves together, tearing these wires will lead to a need for additional repair.
  6. Uniden D1483-3BK Circuit Board/Screen Replacement: 手順 6、 2の画像 1 Uniden D1483-3BK Circuit Board/Screen Replacement: 手順 6、 2の画像 2
    • Carefully remove the 9mm Phillips #1 screw from the top corner of the circuit board.
  7. Uniden D1483-3BK Circuit Board/Screen Replacement: 手順 7、 2の画像 1 Uniden D1483-3BK Circuit Board/Screen Replacement: 手順 7、 2の画像 2
    • Carefully grasp either side of the circuit board and lift it straight out of the front half of the case.
    • Set the board in the lower half of the case.
  8. Uniden D1483-3BK Circuit Board/Screen Replacement, Circuit Board/Screen: 手順 8、 1の画像 1
    • Set the circuit board on the table with the screen facing down.
  9. Uniden D1483-3BK Circuit Board/Screen Replacement: 手順 9、 1の画像 1
    • Using the desoldering braid and soldering iron, remove the solder around the cable for the speaker.
    • When installing the new board, use the soldering iron and solder to reattach the speaker cables.
終わりに
6 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Arbitrary Name
メンバー登録日: 01/28/15
1,083 ポイント
4のガイドは作成済み
チーム
Penn State, Team 1-8, Kaschak Winter 2015 Penn State, Team 1-8, Kaschak Winter 2015人のメンバー
PSU-KASCHAK-W15S1G8
4 メンバー
8のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 24
今までの合計 473
