メインコンテンツにスキップ
Unibody MacBook Pro 15" Glass Replacement
必要な工具と部品
  1. Unibody MacBook Pro 15" Glass Replacement, Prepare a Workspace: 手順 1、 1の画像 1
    • Set up a clean workspace and gather all supplies. You will need your Macbook Pro, a new screen, a hair dryer, a screen cleaning cloth, and a suction cup.
  2. Unibody MacBook Pro 15" Glass Replacement, Heat the Edges of the Screen: 手順 2、 2の画像 1 Unibody MacBook Pro 15" Glass Replacement, Heat the Edges of the Screen: 手順 2、 2の画像 2
    • Use a hair dryer to heat the adhesive around the edges of the screen you are removing.
  3. Unibody MacBook Pro 15" Glass Replacement, Use suction to remove the Screen: 手順 3、 3の画像 1 Unibody MacBook Pro 15" Glass Replacement, Use suction to remove the Screen: 手順 3、 3の画像 2 Unibody MacBook Pro 15" Glass Replacement, Use suction to remove the Screen: 手順 3、 3の画像 3
    • Attach the suction cup found in the iFixit repair kit to the corner of your screen, by gently pressing down until it seals. Lift screen away by pulling up on the suction cup key ring.
  4. Unibody MacBook Pro 15" Glass Replacement, Preparing for the New Screen: 手順 4、 2の画像 1 Unibody MacBook Pro 15" Glass Replacement, Preparing for the New Screen: 手順 4、 2の画像 2
    • Use a screen cleaning cloth to buff out any marks on your Macbook Pros screen surface.
    • Use a screen cleaning cloth to buff out any marks on the inside of new glass that will be applied.
  5. Unibody MacBook Pro 15" Glass Replacement, Preparing Screen Adhesive: 手順 5、 2の画像 1 Unibody MacBook Pro 15" Glass Replacement, Preparing Screen Adhesive: 手順 5、 2の画像 2
    • Remove the strips covering the adhesive on the new screen.
    • Heat the new adhesive strips evenly using the hair dryer.
  6. Unibody MacBook Pro 15" Glass Replacement, Applying the New Screen: 手順 6、 2の画像 1 Unibody MacBook Pro 15" Glass Replacement, Applying the New Screen: 手順 6、 2の画像 2
    • Place the new screen in position. Confirm that the new screen is properly aligned with the edges of the Macbook Pro.
  7. Unibody MacBook Pro 15" Glass Replacement, Attaching the New Screen: 手順 7、 2の画像 1 Unibody MacBook Pro 15" Glass Replacement, Attaching the New Screen: 手順 7、 2の画像 2
    • Using the screen cleaning cloth carefully press the edges of the screen to seal the adhesive.
  8. Unibody MacBook Pro 15" Glass Replacement, Remove Cover: 手順 8、 1の画像 1
    • Peel the protective covering off the new screen.
  9. Unibody MacBook Pro 15" Glass Replacement, Reheat the Adhesive: 手順 9、 3の画像 1 Unibody MacBook Pro 15" Glass Replacement, Reheat the Adhesive: 手順 9、 3の画像 2 Unibody MacBook Pro 15" Glass Replacement, Reheat the Adhesive: 手順 9、 3の画像 3
    • To insure the seal of the adhesive, reheat it again with the hair drying.
  10. Unibody MacBook Pro 15" Glass Replacement, Final Press: 手順 10、 1の画像 1
    • Finally, use the screen cleaning cloth and carefully press the edges of the screen one more time.
  11. Unibody MacBook Pro 15" Glass Replacement, You did it!: 手順 11、 1の画像 1
    • Enjoy your laptop with it's brand new Glass!
終わりに
This guide provides all instructions necessary to dismantle and replace a Macbook Pro Screen.
43 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Akh1913
メンバー登録日: 10/16/15
1,324 ポイント
1ガイドが承認済み
チーム
PIRL Gadget Garage PIRL Gadget Garage人のメンバー
Community
9 メンバー
10のガイドは作成済み
20件のガイドコメント
How did you know the correct part number for your specific MacBook? Where did you source the glass?
frightanic.com - 返信
I sourced my glass this eBay seller: http://www.ebay.com/usr/beetstech?_trksi...
To find the correct part, I followed iFixit's "ID your Mac" prompts in the parts store, then selected the glass panel from the list of compatible parts.
Hope this helps!
Noah Smith -
Is it useful for internal crack
tiffanyts - 返信
FYI, OWC (Other World Computing, aka macsales.com) has the 15-inch glass for $25, and the 13-inch for $24:
https://eshop.macsales.com/item/Apple/MB... (15-inch)
https://eshop.macsales.com/item/Apple/MB... (13-inch)
…and I just discovered they even have the 17-inch:
One last comment: get the glass as hot as you can!
jiclark - 返信
Does this work for the Late-2013 Retina MacBook Pro (15-inch)?
Brian Shiau - 返信
コメントを追加
統計データ:
過去 24時間: 10
過去 7 日: 109
過去 30 日: 413
今までの合計 136,072
