メインコンテンツにスキップ
Unbranded UB-15MS10 Speaker Replacement
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
必要な工具と部品
  1. Unbranded UB-15MS10 Speaker Replacement, Back Panel: 手順 1、 1の画像 1
    • Remove the cover over the Micro SD outlet by using a plastic opening tool to pry open and push out the cover panel.
  2. Unbranded UB-15MS10 Speaker Replacement: 手順 2、 1の画像 1
    • Remove the two 4-mm #0 screws from the inside of the Micro SD compartment.
  3. Unbranded UB-15MS10 Speaker Replacement: 手順 3、 2の画像 1 Unbranded UB-15MS10 Speaker Replacement: 手順 3、 2の画像 2
    • Insert blue guitar picks in the crease between the top and bottom panels starting on the same end as the Micro SD slot.
    • Inserting the picks directly under the Micro SD compartment was the easiest place to get started. It still requires some force.
  4. Unbranded UB-15MS10 Speaker Replacement: 手順 4、 1の画像 1
    • Insert the black spudger between the guitar picks in order to pry open gaps between the blue guitar picks.
    • As the gaps open, slide the guitar picks along the sides to separate the panels.
  5. Unbranded UB-15MS10 Speaker Replacement: 手順 5、 1の画像 1
    • Pry all four sides apart using the blue guitar picks and the black spudger until they can easily be pried apart by hand.
  6. Unbranded UB-15MS10 Speaker Replacement, Speaker: 手順 6、 1の画像 1
    • Remove the yellow tape from the speaker.
  7. Unbranded UB-15MS10 Speaker Replacement: 手順 7、 1の画像 1
    • Remove the two 4-mm #0 screws holding the speaker in place.
    • The copper-colored plastic piece covering the speaker does not need to be removed from the device, move it to the side to reach the screws.
  8. Unbranded UB-15MS10 Speaker Replacement: 手順 8、 1の画像 1
    • Remove the silver tape covering the speaker's black and red wires.
  9. Unbranded UB-15MS10 Speaker Replacement: 手順 9、 1の画像 1
    • Reflow the solder of the black and red wires from the circuit board by using the soldering iron.
    • For more information about using a soldering iron click here.
終わりに
作成者
7人の作成者と共同で作成されました。
Jordan Turk
メンバー登録日: 09/21/15
331 ポイント
2のガイドは作成済み
チーム
IUPUI, Team 2-1, Baechle Fall 2015 IUPUI, Team 2-1, Baechle Fall 2015人のメンバー
IUPUI-BAECHLE-F15S2G1
3 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 710
