メインコンテンツにスキップ
Unbranded UB-15MS10 Motherboard Replacement
必要な工具と部品
  1. Unbranded UB-15MS10 Motherboard Replacement, Motherboard: 手順 1、 3の画像 1 Unbranded UB-15MS10 Motherboard Replacement, Motherboard: 手順 1、 3の画像 2 Unbranded UB-15MS10 Motherboard Replacement, Motherboard: 手順 1、 3の画像 3
    • Use an opening tool to pry off the memory card door located on the back of the tablet.
  2. Unbranded UB-15MS10 Motherboard Replacement: 手順 2、 1の画像 1
    • Remove the two 1.2mm screws found under the memory card door.
  3. Unbranded UB-15MS10 Motherboard Replacement: 手順 3、 3の画像 1 Unbranded UB-15MS10 Motherboard Replacement: 手順 3、 3の画像 2 Unbranded UB-15MS10 Motherboard Replacement: 手順 3、 3の画像 3
    • Pry around the outside carefully using the black spudger to get in.
    • Putting many opening tools around the edge helps keep it from sealing shut again.
  4. Unbranded UB-15MS10 Motherboard Replacement: 手順 4、 2の画像 1 Unbranded UB-15MS10 Motherboard Replacement: 手順 4、 2の画像 2
    • Remove the ribbon cable by using the black spudger to release the tab and carefully pull out the ribbon cable.
  5. Unbranded UB-15MS10 Motherboard Replacement: 手順 5、 3の画像 1 Unbranded UB-15MS10 Motherboard Replacement: 手順 5、 3の画像 2 Unbranded UB-15MS10 Motherboard Replacement: 手順 5、 3の画像 3
    • Peel up the grey tape so that you can get to the board and untape the ribbon cable that was removed from the motherboard in the previous step.
  6. Unbranded UB-15MS10 Motherboard Replacement: 手順 6、 2の画像 1 Unbranded UB-15MS10 Motherboard Replacement: 手順 6、 2の画像 2
    • Remove the five 1.2mm screws from the board.
  7. Unbranded UB-15MS10 Motherboard Replacement: 手順 7、 1の画像 1
    • Use an opening tool to remove the board from the case.
  8. Unbranded UB-15MS10 Motherboard Replacement: 手順 8、 2の画像 1 Unbranded UB-15MS10 Motherboard Replacement: 手順 8、 2の画像 2
    • Detach the three ribbon cables using a spudger
    • Desolder the black, white, and red wires.
  9. Unbranded UB-15MS10 Motherboard Replacement: 手順 9、 1の画像 1
    • Unscrew the two 1.2mm screws from the speaker.
    • These screws are wired to the motherboard.
  10. Unbranded UB-15MS10 Motherboard Replacement: 手順 10、 1の画像 1
    • Unscrew the two 1.2mm screws of the other speaker.
    • These screws are also wired to the motherboard.
  11. Unbranded UB-15MS10 Motherboard Replacement: 手順 11、 1の画像 1
    • Remove the old motherboard from the tablet.
    • Take the new motherboard and solder the black wire of the board to the black wire of the battery.
    • Do the same for the white and red wires.
終わりに
To reassemble your device, follow steps 1-10 in reverse order.
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Matthew Sylvia
メンバー登録日: 03/08/17
280 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team S5-G5, Botvin Spring 2017 UMass Dartmouth, Team S5-G5, Botvin Spring 2017人のメンバー
UMASSD-BOTVIN-S17S5G5
3 メンバー
4のガイドは作成済み
コメント 1 件
Please where can I get the motherboard or charging IC of UB15MS10
Ayo Olowo - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 24
今までの合計 1,171
