メインコンテンツにスキップ
Unbranded UB-15MS10 Battery Replacement
必要な工具と部品
  1. Unbranded UB-15MS10 Battery Replacement, Battery: 手順 1、 1の画像 1
    • Use an opening tool to pry off the lid of the memory card compartment.
  2. Unbranded UB-15MS10 Battery Replacement: 手順 2、 1の画像 1
    • Remove the two 1.2 mm screws within the compartment using a Phillips #00 screwdriver.
  3. Unbranded UB-15MS10 Battery Replacement: 手順 3、 2の画像 1 Unbranded UB-15MS10 Battery Replacement: 手順 3、 2の画像 2
    • Insert opening tools to partially pry open the cover.
  4. Unbranded UB-15MS10 Battery Replacement: 手順 4、 1の画像 1
    • With the cover being partially held open, slide a spudger around the seam to pry off the cover.
  5. Unbranded UB-15MS10 Battery Replacement: 手順 5、 1の画像 1
    • Remove the tape that is holding the battery in place.
  6. Unbranded UB-15MS10 Battery Replacement: 手順 6、 1の画像 1
    • Cut the wires connecting the battery to the device using a pair of wire cutters.
  7. Unbranded UB-15MS10 Battery Replacement: 手順 7、 1の画像 1
    • Carefully remove the battery, making sure that all wires are disconnected.
  8. Unbranded UB-15MS10 Battery Replacement: 手順 8、 1の画像 1
    • Splice the new battery with the red, white, and black wires connected to the motherboard.
終わりに
To reassemble your device, follow directions 1-7 in reverse order.
3 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Evan Peterson
メンバー登録日: 03/08/17
320 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team S5-G5, Botvin Spring 2017 UMass Dartmouth, Team S5-G5, Botvin Spring 2017人のメンバー
UMASSD-BOTVIN-S17S5G5
3 メンバー
4のガイドは作成済み
コメント 1 件
No wonder this tablet was not a big success for Best Buy. Cutting the battery cables has to be an engineering nightmare. It makes no sense to solder something like a battery to the motherboard knowing fully well it has to be replaced in the near future. The engineer that designed this hopefully is in the unemployment line.
Milton Carroll - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 17
今までの合計 2,173
