メインコンテンツにスキップ
Umbrella Stretcher to Rib Joint Repair
必要な工具と部品
  1. Umbrella Stretcher to Rib Joint Repair, Umbrella Stretcher to Rib Joint Repair: 手順 1、 2の画像 1 Umbrella Stretcher to Rib Joint Repair, Umbrella Stretcher to Rib Joint Repair: 手順 1、 2の画像 2
    • Take the broken part of the stretcher to rib joint.
    • Realign it with the rib assembly.
  2. Umbrella Stretcher to Rib Joint Repair: 手順 2、 1の画像 1
    • Take the needle and carefully pass it through one of the holes as seen in the picture.
    • Then pull it back to the same side you went through.
  3. Umbrella Stretcher to Rib Joint Repair: 手順 3、 1の画像 1
    • Take the needle and pass it under the stretcher (not through the middle).
  4. Umbrella Stretcher to Rib Joint Repair: 手順 4、 1の画像 1
    • Position the needle so that it faces the second hole from the same side you just went through in step 3.
    • Take the needle and pass it through the second hole.
    • Then position the needle so that it faces the first hole from the same side you just went through.
  5. Umbrella Stretcher to Rib Joint Repair: 手順 5、 2の画像 1 Umbrella Stretcher to Rib Joint Repair: 手順 5、 2の画像 2
    • Repeat steps 2-4 until the two pieces are held tightly together.
    • Tie a knot to secure it.
    • Refer to step six if the rib punctured the canopy.
  6. Umbrella Stretcher to Rib Joint Repair: 手順 6、 2の画像 1 Umbrella Stretcher to Rib Joint Repair: 手順 6、 2の画像 2
    • It is easier to sew when the canopy is closed
    • Take the hole, hold each end and pull outward into a line.
    • Make sure that it is in line with the umbrella canopy seam.
    • Take the needle and thread and form a hemming stitch (see Step 7).
  7. Umbrella Stretcher to Rib Joint Repair: 手順 7、 3の画像 1 Umbrella Stretcher to Rib Joint Repair: 手順 7、 3の画像 2 Umbrella Stretcher to Rib Joint Repair: 手順 7、 3の画像 3
    • Begin with a threaded needle and start the stitch at one end of the hole and pull the needle all the way until just before the thread runs out.
    • Then loop back around and go through again.
    • Repeat until you reach the other end.
    • You can form the stitch multiple times to make it more secure.
終わりに
The umbrella is fixed now, you may now use the umbrella freely.
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Rodrigo Soliva
メンバー登録日: 10/26/17
182 ポイント
1ガイドが承認済み
チーム
DePaul University, Team S1-G8, Dush Fall 2017 DePaul University, Team S1-G8, Dush Fall 2017人のメンバー
DPU-DUSH-F17S1G8
2 メンバー
1のガイドは作成済み
2 件のコメント
I have a problem with the auto lock, it's a knight bridge umbrella, when i retract it, it doesn't lock in place, can it be fixed or replace the handle in case it's totally eroded?
kamec 01 - 返信
I have 2 umbrellas which have both snapped at the hole. Is there a way this technique or a version of it can be used to repair them?
Jenny - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 30
過去 30 日: 199
今までの合計 11,635
