メインコンテンツにスキップ
Ultimate Ears Wonderboom 3 Speaker Drivers Replacement
必要な工具と部品
  1. Ultimate Ears Wonderboom 3 Speaker Drivers Replacement, Speaker Mesh: 手順 1、 3の画像 1 Ultimate Ears Wonderboom 3 Speaker Drivers Replacement, Speaker Mesh: 手順 1、 3の画像 2 Ultimate Ears Wonderboom 3 Speaker Drivers Replacement, Speaker Mesh: 手順 1、 3の画像 3
    • To unclip the top of the speaker from the body, insert the metal spudger to the left of the speaker's center. To find the correct position, make sure the pointed end of the spudger is inserted entirely.
    • While in this position, press down and into the speaker to unclip the top. You should feel and hear and audible click.
    • Repeat this on all four sides of the speaker. The speaker's top will snap off when you press down on it, so make sure you hold onto the top so it does not fly off.
  2. Ultimate Ears Wonderboom 3 Speaker Drivers Replacement: 手順 2、 1の画像 1
    • Take the top off of the speaker to reveal the inside of the speaker.
    • Carefully set the top cover to the side and make sure the clear plastic button tabs stay intact.
  3. Ultimate Ears Wonderboom 3 Speaker Drivers Replacement: 手順 3、 2の画像 1 Ultimate Ears Wonderboom 3 Speaker Drivers Replacement: 手順 3、 2の画像 2
    • Take the mesh covering off of the speaker by pressing on the center of the speaker and pulling the mesh upwards.
  4. Ultimate Ears Wonderboom 3 Speaker Drivers Replacement, Speaker Drivers: 手順 4、 1の画像 1
    • Unscrew the four M3 x 6mm Phillips head screws in each corner of the speaker.
  5. Ultimate Ears Wonderboom 3 Speaker Drivers Replacement: 手順 5、 1の画像 1
    • Using the metal spudger, slowly wedge it behind the speaker.
    • Slowly and gently push the spudger forward to dislodge waterproofing adhesive that holds the speaker in place.
    • This step will affect the waterproof quality of the speaker.
  6. Ultimate Ears Wonderboom 3 Speaker Drivers Replacement: 手順 6、 1の画像 1
    • Pull the speaker driver forward to dislodge it from the speaker.
    • Next, turn the speaker driver to where the wires are facing upwards.
  7. Ultimate Ears Wonderboom 3 Speaker Drivers Replacement: 手順 7、 1の画像 1
    • Using the soldering iron, desolder the white and black wires (the 2 connections) at the top of the speaker driver.
終わりに
作成者
3人の作成者と共同で作成されました。
Madelyn Woodard
メンバー登録日: 01/23/24
611 ポイント
5のガイドは作成済み
チーム
Western Carolina University, Team 1-3, Virtue Spring 2024 Western Carolina University, Team 1-3, Virtue Spring 2024人のメンバー
WCU-VIRTUE-S24S1G3
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 32
今までの合計 104
