メインコンテンツにスキップ
Ultimate Ears Wonderboom 3 Holding Strap Replacement
必要な工具と部品
  1. Ultimate Ears Wonderboom 3 Holding Strap Replacement, Speaker Mesh: 手順 1、 3の画像 1 Ultimate Ears Wonderboom 3 Holding Strap Replacement, Speaker Mesh: 手順 1、 3の画像 2 Ultimate Ears Wonderboom 3 Holding Strap Replacement, Speaker Mesh: 手順 1、 3の画像 3
    • To unclip the top of the speaker from the body, insert the metal spudger to the left of the speaker's center. To find the correct position, make sure the pointed end of the spudger is inserted entirely.
    • While in this position, press down and into the speaker to unclip the top. You should feel and hear and audible click.
    • Repeat this on all four sides of the speaker. The speaker's top will snap off when you press down on it, so make sure you hold onto the top so it does not fly off.
  2. Ultimate Ears Wonderboom 3 Holding Strap Replacement: 手順 2、 1の画像 1
    • Take the top off of the speaker to reveal the inside of the speaker.
    • Carefully set the top cover to the side and make sure the clear plastic button tabs stay intact.
  3. Ultimate Ears Wonderboom 3 Holding Strap Replacement: 手順 3、 2の画像 1 Ultimate Ears Wonderboom 3 Holding Strap Replacement: 手順 3、 2の画像 2
    • Take the mesh covering off of the speaker by pressing on the center of the speaker and pulling the mesh upwards.
  4. Ultimate Ears Wonderboom 3 Holding Strap Replacement, Holding Strap: 手順 4、 2の画像 1 Ultimate Ears Wonderboom 3 Holding Strap Replacement, Holding Strap: 手順 4、 2の画像 2
    • Grabbing the top of the speaker that was removed earlier, remove both of the strap endings that are stuck through as seen above.
    • Feed the strap through the hole and pull it out.
終わりに
作成者
1人の作成者と共同作成されました。
Madelyn Woodard
メンバー登録日: 01/23/24
611 ポイント
5のガイドは作成済み
チーム
Western Carolina University, Team 1-3, Virtue Spring 2024 Western Carolina University, Team 1-3, Virtue Spring 2024人のメンバー
WCU-VIRTUE-S24S1G3
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 11
今までの合計 45
