メインコンテンツにスキップ
Udi Discovery U818A FPV Camera Replacement
必要な工具と部品
  1. Udi Discovery U818A FPV Camera Replacement, Camera: 手順 1、 1の画像 1
    • Place the drone on its back, with the runners facing upward.
    • Using the Phillips #00 screwdriver, unscrew the single 2mm screw located on the drone body which connects the headlamp and wiring to the center of the drone frame.
  2. Udi Discovery U818A FPV Camera Replacement: 手順 2、 1の画像 1
    • Grasp one of the propeller arms with the fingers of one hand while holding the drone frame with the other hand.
    • Firmly pull the propeller arm upward to separate it from the drone body.
    • Repeat this process to remove the three other propeller arms.
  3. Udi Discovery U818A FPV Camera Replacement: 手順 3、 1の画像 1
    • Carefully remove the drone body from the frame.
  4. Udi Discovery U818A FPV Camera Replacement: 手順 4、 2の画像 1 Udi Discovery U818A FPV Camera Replacement: 手順 4、 2の画像 2
    • Flip the drone body onto the runners so the wires and motherboard are facing upward.
    • Disconnect the black and blue camera wires from the motherboard.
    • You may need to use a pointed metal pick to loosen the red putty that holds the connectors together.
  5. Udi Discovery U818A FPV Camera Replacement: 手順 5、 1の画像 1
    • Be careful when separating the camera away from the runners and drone body—the plastic is brittle and may snap, causing injury to the hand.
    • Pry the camera away from the main drone body.
    • Use a spudger for extra leverage if the parts do not easily separate.
終わりに
作成者
4人の作成者と共同で作成されました。
Debra Crawford
メンバー登録日: 10/11/18
401 ポイント
3のガイドは作成済み
チーム
Eastern Washington University, Team S4-G2, Crane Fall 2018 Eastern Washington University, Team S4-G2, Crane Fall 2018人のメンバー
EWU-CRANE-F18S4G2
2 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 14
今までの合計 289
