メインコンテンツにスキップ
はじめに
The purpose of the speaker on the UTStarcom CDM8945vw device is to produce audio that can be heard by the listener on a call. This component is important if the caller wants to receive auditory information from the person on the other end of the line. If the speaker is not working on the device, then follow this guide to properly replace the speaker.
There are no special requirements nor are there any harmful hazards present in replacing the speaker.
パーツ
パーツは指定されていません。
  1. UTStarcom CDM8945vw Speaker Replacement, Battery: 手順 1、 1の画像 1
    • Push the highlighted button in the direction in which the antenna is pointing. The battery will release and pop up.
  2. UTStarcom CDM8945vw Speaker Replacement: 手順 2、 1の画像 1
    • Remove the battery.
  3. UTStarcom CDM8945vw Speaker Replacement, Antenna: 手順 3、 1の画像 1
    • Identify the antenna. It is the extendable plastic component pictured here.
  4. UTStarcom CDM8945vw Speaker Replacement: 手順 4、 1の画像 1
    • Twist the base in a counter-clockwise motion to unscrew the antenna.
  5. UTStarcom CDM8945vw Speaker Replacement: 手順 5、 2の画像 1 UTStarcom CDM8945vw Speaker Replacement: 手順 5、 2の画像 2
    • The antenna should slide right out of the phone when finished.
  6. UTStarcom CDM8945vw Speaker Replacement, Speaker: 手順 6、 1の画像 1
    • Remove the small rubber grommet using the plastic opening tool.
  7. UTStarcom CDM8945vw Speaker Replacement: 手順 7、 1の画像 1
    • Remove five screws using a Phillips #00 screwdriver.
  8. UTStarcom CDM8945vw Speaker Replacement: 手順 8、 1の画像 1
    • Use the plastic opening tool to separate the two pieces that form the outer case of the phone.
    • Prying the two pieces apart may be difficult. Carefully apply a moderate amount of pressure when attempting to separate the two pieces or else you will risk breaking them.
  9. UTStarcom CDM8945vw Speaker Replacement: 手順 9、 1の画像 1
    • Remove the back piece of the outer case.
  10. UTStarcom CDM8945vw Speaker Replacement: 手順 10、 1の画像 1
    • Remove the speaker using a plastic opening tool.
    • Apply a small amount of force when removing the broken speaker from the motherboard. If you apply a large amount of force, you may rip out the wires and damage the motherboard.
  11. UTStarcom CDM8945vw Speaker Replacement: 手順 11、 2の画像 1 UTStarcom CDM8945vw Speaker Replacement: 手順 11、 2の画像 2
    • Remove the wire attached to the speaker from the motherboard using tweezers.
    • Apply a small amount of force when removing the wire from the motherboard. If you apply a large amount of force, you may rip out the wires and damage the motherboard.
終わりに
Eli
メンバー登録日: 2012年09月27日
1 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 24-26, Regan Fall 2012 Cal Poly, Team 24-26, Regan Fall 2012人のメンバー
CPSU-REGAN-F12S24G26
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 320
