メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
UTStarcom CDM8945vw Keyboard Replacement
必要な工具と部品
  1. UTStarcom CDM8945vw Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • Push the highlighted button in the direction in which the antenna is pointing. The battery will release and pop up.
  2. UTStarcom CDM8945vw Keyboard Replacement: 手順 2、 1の画像 1
    • Remove the battery.
  3. UTStarcom CDM8945vw Keyboard Replacement, Antenna: 手順 3、 1の画像 1
    • Identify the antenna. It is the extendable plastic component pictured here.
  4. UTStarcom CDM8945vw Keyboard Replacement: 手順 4、 1の画像 1
    • Twist the base in a counter-clockwise motion to unscrew the antenna.
  5. UTStarcom CDM8945vw Keyboard Replacement: 手順 5、 2の画像 1 UTStarcom CDM8945vw Keyboard Replacement: 手順 5、 2の画像 2
    • The antenna should slide right out of the phone when finished.
  6. UTStarcom CDM8945vw Keyboard Replacement, Speaker: 手順 6、 1の画像 1
    • Remove the small rubber grommet using the plastic opening tool.
  7. UTStarcom CDM8945vw Keyboard Replacement: 手順 7、 1の画像 1
    • Remove five screws using a Phillips #00 screwdriver.
  8. UTStarcom CDM8945vw Keyboard Replacement: 手順 8、 1の画像 1
    • Use the plastic opening tool to separate the two pieces that form the outer case of the phone.
    • Prying the two pieces apart may be difficult. Carefully apply a moderate amount of pressure when attempting to separate the two pieces or else you will risk breaking them.
  9. UTStarcom CDM8945vw Keyboard Replacement: 手順 9、 1の画像 1
    • Remove the back piece of the outer case.
  10. UTStarcom CDM8945vw Keyboard Replacement: 手順 10、 1の画像 1
    • Remove the speaker using a plastic opening tool.
    • Apply a small amount of force when removing the broken speaker from the motherboard. If you apply a large amount of force, you may rip out the wires and damage the motherboard.
  11. UTStarcom CDM8945vw Keyboard Replacement: 手順 11、 2の画像 1 UTStarcom CDM8945vw Keyboard Replacement: 手順 11、 2の画像 2
    この手順で使用する道具:
    • Remove the wire attached to the speaker from the motherboard using tweezers.
    • Apply a small amount of force when removing the wire from the motherboard. If you apply a large amount of force, you may rip out the wires and damage the motherboard.
  12. UTStarcom CDM8945vw Keyboard Replacement, Logic Board: 手順 12、 1の画像 1
    • Detach the highlighted piece from the logic board using a plastic opening tool.
  13. UTStarcom CDM8945vw Keyboard Replacement: 手順 13、 2の画像 1 UTStarcom CDM8945vw Keyboard Replacement: 手順 13、 2の画像 2
    • Remove the logic board from the anterior piece of the outer case using the plastic opening tool.
  14. UTStarcom CDM8945vw Keyboard Replacement, Keyboard: 手順 14、 1の画像 1
    • Remove the keyboard.
終わりに
作成者
4人の作成者と共同で作成されました。
Bryon Hazlewood
メンバー登録日: 10/03/12
1 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 24-26, Regan Fall 2012 Cal Poly, Team 24-26, Regan Fall 2012人のメンバー
CPSU-REGAN-F12S24G26
4 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 33
今までの合計 454
