はじめに
Without the proper power ratings the printer can behave very strangely and will generally produce worse results. The provided power supply is known to go bad for various reasons. Unforunately the motherboard can be fried out as well, which may be the real root of your problem.
パーツ
パーツは必要ありません。
  1. Always be wary of plugging in suspected broken electronics into mains voltage of 120/220 VAC! IF SOMETHING SMOKES OR SMELLS BAD UNPLUG IT IMMEDIATELY! Verify that the power adapter into the transformer brick itself is plugged in securely.
    • Always be wary of plugging in suspected broken electronics into mains voltage of 120/220 VAC! IF SOMETHING SMOKES OR SMELLS BAD UNPLUG IT IMMEDIATELY!
    • Verify that the power adapter into the transformer brick itself is plugged in securely.
    • Check that the particular wall socket you are using is hot (plug in your phone charger and make sure it charges your phone).
    • Plug in the power supply to the wall outlet, but DO NOT plug it into the printer yet!
    • Check for a blue LED to come on to say the unit is powered up.
  2. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Measure the output voltage of your power supply with a voltmeter or multimeter on the Volts DC setting.
    • Measure the output voltage of your power supply with a voltmeter or multimeter on the Volts DC setting.
    • To measure, insert the positive (red) probe into the middle of the connector while at the same time touching the outside metal jacket.
    • Make sure to make good contacts but not to short the two leads out by touching them together.
    • The multimeter should read anywhere between 18.5-20 Volts DC. This is the normal operating range of the power supply, if it outputs less than 16 Volts or more than 20 Volts your power supply is defective.
    • If you read correct voltage but your printer is still malfunctioning, continue with the guide.
  4. Plug in the power connector and turn on the machine by depressing the rocker switch on the rear towards the line.
    • Plug in the power connector and turn on the machine by depressing the rocker switch on the rear towards the line.
    • Does the red/green light on the front come on? If it does, your power supply is perfectly operational.
    • If the front lights do not come on at all this is generally an issue with the main board or the control board, which, in any case should be handled by the professionals who sell the printer. At this point you need to send in your printer for service. Sorry!
まとめ
Hopefully this guide helped you diagnose some of the issues that you might be experiencing with your printer.
valerie boyer
メンバー登録日: 2014年10月12日
469 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 14-31, Maness Fall 2014 Cal Poly, Team 14-31, Maness Fall 2014人のメンバー
CPSU-MANESS-F14S14G31
4 メンバー
5のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 814
