メインコンテンツにスキップ
UP! Plus 2 Spool Holder Replacement
必要な工具と部品
  1. UP! Plus 2 Spool Holder Replacement, 3D print replacement spool holder: 手順 1、 1の画像 1
    • Before your spool holder breaks, 3D print a replacement to have on hand. If you didn't preemptively print a replacement you can still print without a spool holder. Just find some way of holding the spool so that it can rotate as the filament gets pulled off.
    • Download the file for a new spool holder here
  2. UP! Plus 2 Spool Holder Replacement, Remove plastic filaments: 手順 2、 3の画像 1 UP! Plus 2 Spool Holder Replacement, Remove plastic filaments: 手順 2、 3の画像 2 UP! Plus 2 Spool Holder Replacement, Remove plastic filaments: 手順 2、 3の画像 3
    • Go to "Maintenance" and tell the printer to withdraw the plastic filament from the extrusion assembly. Finish removing the filament by pulling upwards.
    • Wait for a "beeping" sound before removing filament.
    • Cut off any damaged plastic from the end of the filament.
    • Remove the plastic filament tube from the spool.
  3. UP! Plus 2 Spool Holder Replacement, Remove spool holder: 手順 3、 3の画像 1 UP! Plus 2 Spool Holder Replacement, Remove spool holder: 手順 3、 3の画像 2 UP! Plus 2 Spool Holder Replacement, Remove spool holder: 手順 3、 3の画像 3
    • Remove the spool from the spool holder by lifting it up and taking it off.
    • Put the end of the filament through the hole on the side of the spool to keep it from unraveling.
    • Slide the spool holder upwards, and then pull outwards.
  4. UP! Plus 2 Spool Holder Replacement, Replace spool holder: 手順 4、 3の画像 1 UP! Plus 2 Spool Holder Replacement, Replace spool holder: 手順 4、 3の画像 2 UP! Plus 2 Spool Holder Replacement, Replace spool holder: 手順 4、 3の画像 3
    • Place the new spool holder by pushing it inwards and sliding it down until it locks.
    • Repeat the steps in reverse chronological order to reassemble the printer.
    • The spool should be inserted in way that end of the filament points towards, not away.
ゴール
6 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
valerie boyer
メンバー登録日: 10/12/14
508 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 14-31, Maness Fall 2014 Cal Poly, Team 14-31, Maness Fall 2014人のメンバー
CPSU-MANESS-F14S14G31
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 11
過去 30 日: 16
今までの合計 1,216
