メインコンテンツにスキップ
Logitech UE Boom Bluetooth Adapter Replacement
必要な工具と部品
  1. Logitech UE Boom Bluetooth Adapter Replacement, D-ring: 手順 1、 1の画像 1
    • Turn the device over. The D-ring will be on the left face of the speaker when viewing the device from this orientation.
  2. Logitech UE Boom Bluetooth Adapter Replacement: 手順 2、 2の画像 1 Logitech UE Boom Bluetooth Adapter Replacement: 手順 2、 2の画像 2
    • Lift the handle on the D-ring and unscrew it.
    • Remove the D-ring.
  3. Logitech UE Boom Bluetooth Adapter Replacement, Bluetooth Adapter: 手順 3、 1の画像 1
    • Any repairs made from this point forward will void your device's warranty.
    • Holding the speaker upright, wedge the metal spudger in between the casing and the speaker. Gently pry open the tabs as they are easily broken.
  4. Logitech UE Boom Bluetooth Adapter Replacement: 手順 4、 3の画像 1 Logitech UE Boom Bluetooth Adapter Replacement: 手順 4、 3の画像 2 Logitech UE Boom Bluetooth Adapter Replacement: 手順 4、 3の画像 3
    • Find the part of the casing that covers the volume controls. Wedge the metal spudger under this and pry open all of the tabs as in the previous step.
    • Repeat for the bottom of the speaker and pry the casing open with your fingers.
  5. Logitech UE Boom Bluetooth Adapter Replacement: 手順 5、 2の画像 1 Logitech UE Boom Bluetooth Adapter Replacement: 手順 5、 2の画像 2
    • Using the Phillips J0 head screwdriver, unscrew the four silver 9 mm screws.
    • Do the same for the two black 7 mm screws.
  6. Logitech UE Boom Bluetooth Adapter Replacement: 手順 6、 3の画像 1 Logitech UE Boom Bluetooth Adapter Replacement: 手順 6、 3の画像 2 Logitech UE Boom Bluetooth Adapter Replacement: 手順 6、 3の画像 3
    • This next step involves the use of a hot soldering iron. Remember to be careful during this step since it can be easy to burn yourself.
    • Using a soldering iron, de-solder the two ends of the switch plate.
  7. Logitech UE Boom Bluetooth Adapter Replacement: 手順 7、 1の画像 1
    • With the switch plate disconnected, remove it and your device should now look like this.
終わりに
6 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Jose Cruz Arinaga
メンバー登録日: 10/01/15
1,003 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 4-1, Maness Fall 2015 Cal Poly, Team 4-1, Maness Fall 2015人のメンバー
CPSU-MANESS-F15S4G1
4 メンバー
22のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 17
過去 30 日: 44
今までの合計 11,210
