この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will show how the speaker of the UE Boom 2 is removed. This is an extensive and intrusive process which removes most components of the speaker.
必要な工具と部品
Remove the D-ring located at the bottom of the device, opposite end of the power button.
Remove by twisting in a counter-clockwise motion.
Removing the D-ring will allow you to be able to remove the rubber port cover revealing the headphone jack and charging port.
Using the metal spudger, specifically the pointy end, find the gap between the speaker and billow (the large speaker-like object next to the speaker).
Pry the metal wire up and out at exactly this gap, then slide down wire towards one end to pop it out completely.
Once one end is out, use fingers to gently pull off completely, so as not to bend the wire to aggressively.
11 の人々がこのガイドを完成させました。
10 件のコメント
Hi, very good tutorial, you got your 30 points ! ;)
But the main question remains to me : where to get a new speaker as UE doen’t sell spare parts and I don’t find any replacement on internet … any help more than welcome …
Cheers!
did you managed to source a replacement speaker? im having the same problem
Still did not find replacement … what about you guys ?
Check my update you may not have to buy a replacement
Check with a multimeter if the speakers are actually faulty. Mine were fine, turns out another component broke off and so I soldered it back on. Now it works fine.
Stig -
