はじめに
If your Turtle Beach Recon Cloud controller won’t hold a charge or has a damaged battery, replacing the lithium-ion battery can restore wireless play and extend the life of the controller.
This guide shows how to replace the battery in a Turtle Beach Recon Cloud controller.
Before you begin, power off the controller and disconnect it from your PC, console, and any charging cables.
必要な工具と部品
Insert a spudger between the controller and the battery pack.
Use the spudger to loosen the battery from the motherboard.
Gently lift the battery pack until just out so as to not pull on the wire attached.
Use the point of a spudger to push on alternating sides of the battery connector to "walk" it out of its socket.
If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
