メインコンテンツにスキップ
Turtle Beach Ear Force XO Seven Speaker Cone Replacement
必要な工具と部品
  1. Turtle Beach Ear Force XO Seven Speaker Cone Replacement, Ear Pad: 手順 1、 2の画像 1 Turtle Beach Ear Force XO Seven Speaker Cone Replacement, Ear Pad: 手順 1、 2の画像 2
    • Begin by placing your thumb on the plastic edge around the ear pad.
    • Get a good grip around the ear pad and gently separate it from the headset.
    • Apply the same instructions to remove the other foam pad off of the headset.
    • Make sure you continue to gently peel the ear pad from the headset until completely removed.
  2. Turtle Beach Ear Force XO Seven Speaker Cone Replacement, Speaker Cone: 手順 3、 2の画像 1 Turtle Beach Ear Force XO Seven Speaker Cone Replacement, Speaker Cone: 手順 3、 2の画像 2
    • A new speaker cone for these headphones will cost about $8 to $10 from amazon.com.
    • After removing the ear pads, unscrew the four Phillips head screws that hold the front plate on.
    • To avoid losing small screws, place them in a container.
  3. Turtle Beach Ear Force XO Seven Speaker Cone Replacement: 手順 4、 2の画像 1 Turtle Beach Ear Force XO Seven Speaker Cone Replacement: 手順 4、 2の画像 2
    • When removing the speaker cone plate, be careful not to drop it or put stress on the wires as they are very delicate.
    • Remove the speaker cone plate on a flat surface to prevent unnecessary stress on the wires.
    • The speaker cone is attached to the front plate. To replace, unsolder the wires from the two connection points.
  4. Turtle Beach Ear Force XO Seven Speaker Cone Replacement: 手順 5、 1の画像 1
    • Replace the speaker cone carefully in place of the old one.
    • Consider tinning the wires before soldering them on to the new speaker cone.
    • Solder the wires back on to the new speaker cone.
    • Reassemble the front plate.
終わりに
3 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Jacob
メンバー登録日: 01/31/15
166 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 17-36, Amido Winter 2015 Cal Poly, Team 17-36, Amido Winter 2015人のメンバー
CPSU-AMIDO-W15S17G36
4 メンバー
12のガイドは作成済み
3 件のコメント
I couldn't find the speaker cone at amazon. Does anyone have a link?
victorlborges - 返信
You need to buy a Broken Headset the use that to replace the speaker.
Andy Millett - 返信
Is there anywhere that i can buy replacement swivel part that hold the speaker
Robert bee - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 6
今までの合計 5,506
