必要な工具と部品
Using a Philips head screwdriver, unscrew the two screws on the back of the adapter.
The recommended screwdriver bit size is a PH 000.
Using your hands and/or a prying tool, carefully pry open the adapter.
This step may require a bit of force to complete.
Be aware that the adapter is held together with clips on the inside at some locations.
Do not be alarmed if it makes a snapping sound as it comes apart, this is most likely just the sound of the clips detaching.
ある他の人がこのガイドを完成しました。
